I can’t really see for sure, but there should be some welt between the crash pad and the top of the facia.
It's there, and proper black.I can’t really see for sure, but there should be some welt between the crash pad and the top of the facia.
Doc,As JP states, NO "permanent" sealant for the bezels. Scroll up to my #16 post above. Here's another llink >to Nisonger Instruments.< They sell the gasket set for all the gauges for skinny money, even with the cost of the shipping. Save yourself the aggro.
Otherwise, looks like some good progress!
That fitting for the oil pressure gauge had a small diameter flat seal for the seat, may still be in the ferrule? ISTR it was thin leather originally, but I may be mistaken. Again, no sealant, the fitting and ferrule are a tapered seat. Look for it on Nisonger's site at the same time as the gauge gaskets.
Keep us posted.![]()
Hiya, D! The OP has the welting in between facia and pad, just in black.I was referring to OPs picture, Doc.
My B originally had white piping, so when I redo the interior I might steal that trick you have done.
Chris,Doc,
This Permatex form-A seal seals but does not bond , slow drying but does not harden and is easily removed
or 3M strip caulk it seems to have same properties ?
Chris
DocHiya, D! The OP has the welting in between facia and pad, just in black.
My first B, a '66 had it in white, I did this one the same. Glad you approve of the added console.
Chris,
They will both likely turn gooey over time, not familiar with the Form-a-Seal but the 3M strip calk is a butyl and tends to change plasticity with temp. And it's VERY sticky! I'd not use it for a gauge seal. Tho I have used it on the bottom of MGB windshields.
Chris,Doc
I have found a supplier for the replacement o rings for the gauges so going down that path. I kicked her over for the first time
after putting everything back together it sounded great
Chris
DocAh... I mis-stood under you!
If you're inclined to spend the time doing it, it should work. But I'd still say just replace the cable, they're available with the same knob. Not like the earlier hex-shaped shaft end and smaller "C" embossed knob.
Doc ,Doc,
The place is Horward Instruments
Phone 0394574755
110 Heidelberg Road
Heidelberg West
Victoria 3081
Web site horwardinstruments.com.au
I was refered to him by a member of the MG car club of Geelong , I was told he can supply all parts for many gauges .
Have a look at his web site it seems he specialises in Smiths and many others .
I left a message to call me I will let you know how I go with him.
Regards
Chris
Instruments Smith gaugesNow I'm confused. Are you talking about the choke cable or instruments?
Ah. Thanks for clarifying. Have you found faulty instruments, or just wanting to "refresh" and service them?Instruments Smith gauges
