MGB MGB flap and air box
Platinum
I can’t really see for sure, but there should be some welt between the crash pad and the top of the facia.
It's there, and proper black.
We did mine with white welting, just for the contrast. For the padding on the facia top edge I used a "pool noodle" carved it to shape with an electric carving knife. 😉
Grantura_MKI
I was referring to OPs picture, Doc.
My B originally had white piping, so when I redo the interior I might steal that trick you have done.
A
Aussie Chris
As JP states, NO "permanent" sealant for the bezels. Scroll up to my #16 post above. Here's another llink >to Nisonger Instruments.< They sell the gasket set for all the gauges for skinny money, even with the cost of the shipping. Save yourself the aggro.
Otherwise, looks like some good progress!
That fitting for the oil pressure gauge had a small diameter flat seal for the seat, may still be in the ferrule? ISTR it was thin leather originally, but I may be mistaken. Again, no sealant, the fitting and ferrule are a tapered seat. Look for it on Nisonger's site at the same time as the gauge gaskets.
Keep us posted. 👍
Doc,
This Permatex form-A seal seals but does not bond , slow drying but does not harden and is easily removed
or 3M strip caulk it seems to have same properties ?
Chris
Platinum
Hiya, D! The OP has the welting in between facia and pad, just in black.
My first B, a '66 had it in white, I did this one the same. Glad you approve of the added console.
Doc,
Chris
Chris,
They will both likely turn gooey over time, not familiar with the Form-a-Seal but the 3M strip calk is a butyl and tends to change plasticity with temp. And it's VERY sticky! I'd not use it for a gauge seal. Tho I have used it on the bottom of MGB windshields.
A
Aussie Chris
Chris,
Doc
I have found a supplier for the replacement o rings for the gauges so going down that path. I kicked her over for the first time
after putting everything back together it sounded great
Chris
Platinum
Doc
Chris
Chris,
If you wouldn't mind, can you post the supplier of the o-rings? Plenty of folks from your continent could use a source closer to home.
And glad to learn you chimed it up with no issues! 👍
A
Aussie Chris
Doc,
The place is Horward Instruments
Phone 0394574755
110 Heidelberg Road
Heidelberg West
Victoria 3081
Web site horwardinstruments.com.au
I was refered to him by a member of the MG car club of Geelong , I was told he can supply all parts for many gauges .
Have a look at his web site it seems he specialises in Smiths and many others .
I left a message to call me I will let you know how I go with him.
Regards
Chris
A
Aussie Chris
Doc,
I ended up taking all gauges apart cleaned and put new o rings in they were oversized so cut then glued them to make correct size attached two photos one a close up of temp gauge I cleaned and re installed and working all went well.
A question the choke locking key is alright to use mild steel to make a new one
the current is worn and the choke does not lock?
Regards
Chris
Platinum
Guage looks good, Chris.
As for that choke cable lock, the steel ring that "locks" the cable is spring steel. Mild steel is likely to fatigue and fail rather quickly. You ~may~ be able to fuss the "dimple" in the spring with a rounded punch, but frankly that's more trouble than it's worth, IMO. We replaced the cables that stopped working.
A
Aussie Chris
Sorry Doc,
I am talking about the cable lock which sits under spring steel collar a half moon shape bit of steel mine has a grove in it and it does not lock
from what I have observed they can be fashioned from a bolt of the same diameter count to the same width and cut in half to give that flat surface for the cable to lock against.
Chris
Platinum
Ah... I mis-stood under you!
If you're inclined to spend the time doing it, it should work. But I'd still say just replace the cable, they're available with the same knob. Not like the earlier hex-shaped shaft end and smaller "C" embossed knob.
A
Aussie Chris
Doc
left message for Horward Instruments to call me last Friday have not heard back .
Regards
Chris
A
Aussie Chris
Doc,
Phone 0394574755
110 Heidelberg Road
Heidelberg West
Victoria 3081
Regards
Chris
Doc ,
Finally made contact with Howard’s they don’t sell spares but will repair
Chris
Platinum
Now I'm confused. Are you talking about the choke cable or instruments?
Platinum
Platinum
And of course we will want to see pix after you get them back and in place! 😉 👍
And I finally got around to getting a couple wide-angle photos of the dash here in our '64:
Platinum
Chris,
Looking at the photos you'd posted earlier of your dash, I just noticed there's what appears to be an original 3rd/4th gear overdrive switch just right of the fuel gauge? I know yours is a later car, with the four-synchro gearbox. Does it also have the overdrive unit fitted?
If so, that's really nice to have! >jealousy icon here<
Ours here is the three-synchro box, no overdrive. The switch in the position is a headlight switch, intended for an eventual set of period Lucas "Flamethrower" lights. First position on the switch is for the fog lamp only, second position lights both pencil beam and fog. Just now I've a set of Lucas "Square-8's" mounted beneath the bumper, wiring and relays fitted.
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 5
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
AngliaGT ANOTHER TR6,& an MGB Spotted 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
JohnGone Wanted Spare & Jack for an '80 MGB MG Classifieds 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
