MGA Merkur Tranny in an MGA
GB1
The topic pretty much tells all ??? Done, can be done ??? Etc??
That's the unit Moss sells for the MGB..a T-9.
Don't know why it would not work with an MGA...with some alterations and adaptations.
My only fear of the T-9 is the potential scarcity of parts here in the US. There was not that many Merkurs with the T-9 here...it's a more common gearbox in Europe (Ford Sierra).
I would be more tempted to look at the Nissan 280Z/ZX 5-speed transmission and Rivergate conversion kit available.
wdp
The T-9 is good for 200+ horsepower so breakage shouldn't be a problem. Taylor Race Engineering has parts listed in their catalog for the T-9.
That does not mean that something cannot or will not break. And we all know that just because a part is listed in a catalog does not mean that it is stocked or available.
YOMV.
ronzet
Rick,
"YOMV" ????
Thanks
billspohn
Why not just find an early non-synch MGB OD trans. That can also be fitted.
pwlester
I installed one of these transmissions in my TD and Moss has made a commitment to stock parts for it for the foreseeable future. I can't imagine that you will ever actually need any parts running it in an MGA. The Merkur had a far more powerful engine and this is a really nice piece of equipment. The Moss item is a bit pricey but it went in without a hitch and works great.
I agree with these comments...but I tend to ask myself "what if" a lot.
I've a friend here in town that just installed the T9 tranny from Moss into his 1972 MGB tourer...as well as a supercharger. Too snowy and slick to get it out for a true test run yet...I'm looking forward to it!
pwlester
Rick, asking "what if alot" somehow seems incompatible with MG ownership:smile: I thought it was all about blind faith or at least it seems that way in my case. Seriously, this is a modern transmission made from modern alloys. It should be nearly bullit proof in our cars. Paul.
swift6
I wouldn't necessarily call it modern. Its based on the Type E 4-speed that dates back to the late sixties and the five speed (Type-9) has been in use since the early eighties (2.8 litre Capri's in 1982 before the Merkur/Sierra).
pwlester
Swift6, I stand corrected. Compared to my old TD everything seems "modern" Still, the list of uses you give must be some indication that it is a very servicable unit. Cheers, Paul.
swift6
The T9's are very easy to find in breaker yards in the UK but are a little more scarce over here. Since we didn't really get Mk1&2 Escorts or any of the later (5-Speed)Capri's we primarily have to look for Merkurs. Should be very serviceable if you don't mind sourcing parts from the UK if you find parts harder to find here.
AngliaGT Merkur Scorpio Spotted 3
M Tranny Mount Bolts Spridgets 3
M Tranny Mount Spridgets 1
R Wanted rib cage tranny part Spridgets Classified 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
R Tranny ? Spridgets 3
2 TR2/3/3A Oil leak in tranny Triumph 4
J TR5/TR250 tranny woes Triumph 15
Got_All_4 TR4/4A Interesting Tranny problem Triumph 9
Jim_Gruber 210 Tranny Shop Manual Spridgets 2
Got_All_4 General TR This Happened Twice [TR6 tranny in a TR3] Triumph 17
F Ribbed case tranny in 948 bugeye Spridgets 2
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
M Wanted dATSUN 5 SPEED TRANNY Austin Healey Classifieds 2
Jim_Gruber 210 Tranny Case Mods started this evening Spridgets 15
Got_All_4 TR2/3/3A Something is really wrong? Overdrive Tranny Triumph 7
histerical Datsun tranny help please Spridgets 18
histerical Tranny build Spridgets 0
M TR2/3/3A Engine/tranny angle with the ground? Triumph 7
GTP1960 TR2/3/3A tr6 Type A OD tranny service Triumph 10
C stupid question on tranny oil Spridgets 9
Got_All_4 General Tech How do i get these out? Tranny cover plugs Triumph 6
BillyB62 Sideshift OD tranny Austin Healey 15
Griz Tranny O/D Austin Healey 2
Got_All_4 TR2/3/3A Steering box oil seal & same seal for input shaft in tranny Triumph 2
Got_All_4 General TR Tranny Fork alinement problems & TR3 shifter in a TR6 tranny Triumph 17
Got_All_4 General TR Identifing the tranny number on my j type Triumph 7
C TR2/3/3A Need Help Identifing Tranny with Overdrive Triumph 4
Rut 210 tranny Spridgets 10
T TR4/4A Want to buy tr4 tranny for my tr3a Triumph 17
R Od/tranny 100-4 Austin Healey 6
D Spitfire '65 Spitfire MKII tranny pblm Triumph 1
Tinkerman TR2/3/3A Continuity Check on Tranny Lock out switches Triumph 2
Tinkerman TR2/3/3A Tranny lock out switches Triumph 9
Got_All_4 TR2/3/3A J type on a TR3 tranny Triumph 3
Tinkerman TR2/3/3A Hole on top of my tranny tunnel Triumph 9
Tinkerman TR2/3/3A 1960 TR3A Holes in the tranny tunnel Triumph 11
T TR4/4A Heat shield for tranny cover Triumph 4
pkmh BJ8 Tranny Issue - Slightly hitting gears when shifting Austin Healey 13
Boggsy64 MGB What is the purpose of the center assembly at tranny mount? MG 2
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
RJS General TR Valvoline VR-1 20W-50 or Straight SAE 50 for OD Tranny? Triumph 16
Lukens TR2/3/3A TR3 A tranny questions. Triumph 8
J TR4/4A Can't get the TR4 tranny and OD to mate up Triumph 12
CJD TR4/4A TR4 or TR3 Tranny? Triumph 5
L Overdrive and tranny oil Austin Healey 19
J BN2 Tranny Jumping Out of 1st Gear Austin Healey 1
C Tranny dip stick question Austin Healey 11
