Tinkerman
I just started a lock out switch ID test. I put the tranny into first gear and checked the switch with my multi meter and I had continuity across the switch. So that one is first and second. Went to the next switch which I figured should be 3rd and 4th. The switch remained open. Tried it several times with the same results. What's wrong? Bad switch? Mechanical problem?
Take the switch out and bench test it?
The car has not been on the road at this point. The tranny is a total rebuild and has been succesfully bench tested.
Your thoughts greatly appreciated!
Thanks, Tinkerman
Thanks, Tinkerman
