Lucas Dizzy with micro timing adjustment question
poolboy
I'm wanting to know what makes that feature work. I know that on dizzys without this feature (like mine) that the vacuum module is pinned to the dizzy housing to keep it in one place.
With the micro or vernier adjustment, it would appear that the module slides in the housing as the adj. wheel is turned. Is that right? Is that reorienting the moving plate?
I was told by Jeff that he could add this to mine, but I didn't think to ask exactly what made it work. So I thought I'd ask here.
TR3driver
Great Pumpkin - R.I.P
Exactly right, on both counts.
Handy for roadside adjustments without a timing light or wrench, but not worth adding, IMO.
Geo Hahn
I've never given a lot of thought to how it works but I think your description is about right.
It can be a handy feature but doesn't do much that you can't accomplish another way.
Might have been useful on the early TRs that had hand-cranks as the timing could be temporarily retarded for easier starting (and less chance of kicking back) then advanced for running.
I use it to fine-tune the timing as the scale lets me know & record exactly what adjustment has been made.
poolboy
poolboy
Thanks guys. I just like fiddlin; seems like just the thing.
tomshobby
Like Paul I like it for making fine adjustments. An adjustment to the timing can be precisely made vs moving the dizzy and re-tightening it.
But, like Randall mentioned, the cost might be a consideration. I just looked at the receipt and it cost $80 to have it added.
My thinking was that while the dizzy was being restored it would be $80. If I decided later that I wanted it the cost would have included the shipping, extra work to take the dizzy apart, the $80, and the time while waiting while it was being done. I made the decision based on the feeling that I would have eventually wanted it anyway. I think it will be particularly useful for any dyno work.
poolboy
poolboy
Yeah, mdl.., that's what I was quoted. I don't think that's bad. I saw the vacuum module for sale at auction that is needed. Has the threaded rod, did not include the adj. wheel or circlip. Stared out at 40 bucks.
"One of these days".....
R
RonMacPherson
With the seasonal changes in the "octane" ratings and increased ethanol in the gases available, might be a good thing to have to adjust on the side of the road, rather than having to break out a light.
poolboy
poolboy
Well it's a long way from Sandy Hook Mississippi to Shankopee Minnesota, but I brought my dizzy to a rural Post Office on Monday, Feb 25. And on Thrusday, Feb 28, it was on Jeff's bench. I picked it up today, Mar 4, at the same rural Post Office.
You guys know Jeff's work so there's no surprise there when I tell you how pleased I am. I also got the micro-adjustment feature installed.
I think the speed at which I got the dizzy back not only says a lot about Jeff, but also the Post Office. How often do you hear that?
Brosky
I hear it a lot about Jeff's work, but have you been drinking that funny tasting water that they serve at the Post Office again????
poolboy
poolboy
www.advanceddistributors.com Jeff Schlemmer. He does whatever it takes to make your distributor look and work like new.
In my case it cost $79.00 plus $80.00 for the addition of the micro adjustment feature. If you can find the micro adjustment unit, it will cost you nearly that just for the part.
JeffS
I REALLY like to add the micro adjust feature to the TR6 distributors - its just seems like a natural fit for the "hot rod" of British cars to have a handy timing adjustment. What I charge isn't out of line for a new replacement vacuum unit - the advance type is available through Moss for $73 (last I checked), but they don't have all the hardware available for the installation. If any of you should decide to order your own "advance" unit as they're called by Moss and make this upgrade, its as easy as drilling the hole through the casting, and I have the necessary hardware kits on hand for $15. If you add up the costs for materials, the labor is less than free because I like doing the work!
As for the kind words - Thank You!!! This is the ONLY thing I've done in my life that I'm proud enough to put my name on, even though I know you guys probably peel the stickers off anyway... :smile:
DNK
Who US????
poolboy
poolboy
:winner1: Jeff Schlemmer. I just got back from a 30 mile test drive after making a small adjustment with the wheel and I've got to say that the difference that the recurve/rebuild made was Quite noticeable.
That little car pulls away so smoothly and when I get to 2400 the pull to 3200 is such a joy and so smooth....man!!. And that's an engine with 99k..
And, I didn't remove the decal.
poolboy
poolboy
Absolutly! And the more I drive it (just got back) the more I appreciate what you did, Jeff.
In fact, I have to say that this was the single most performance enhancing work that I have done or had done, including rebuilding the carbs.
Hard to believe for less than 100 dollars, you can get this kind of results.
If I had any idea rebuilding that distributor would have made that much difference I would have sent it to you within a week of bringing Ol'Basil home.
Brosky
I've been telling everyone this for a long time.
Glad to see that others are getting the same great results that I did.
19_again GT6 Lucas Distributor cap on Delco D204 Dizzy GT6+ Triumph 6
NutmegCT TR2/3/3A Dizzy dizzy - TR3A - Lucas 25D Triumph 18
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
MGTF1250Dave T-Series Lucas Generator MG 1
T Lucas Flasher Unit Austin Healey 5
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
B TR6 Swapped Lucas to GM alternator Triumph 9
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
Lin Lucas coil question Austin Healey 8
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Navigation Questions 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
F T-Series Lucas m133 headlamp? MG 2
S BJ8 Ignition Switch - Lucas Part Number? Austin Healey 4
S Intermotor or Lucas Sport Coil ? Austin Healey 14
C General Tech Lucas Fog Lamps Triumph 2
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
R LUCAS 17L Batteries for Healey 100s Austin Healey 3
C TR6 More fun with Lucas Triumph 5
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
Michael Oritt Lucas 576 lights Austin Healey 4
J MGC Lucas alternator/regulator MG 3
Rob Glasgow Weird Lucas Headlight Austin Healey 7
CJD General Tech Boeing using Lucas parts? Triumph 7
D Wanted lucas wt618 Triumph Classifieds 0
Basil SOLD!! Lucas Spot and Fog lamps Jaguar Classifieds 1
H Lucas Prince of darkness Austin Healey 4
NutmegCT Lucas 432 bulb Restoration & Tools 6
T Lucas HF 1748 horn parts Austin Healey 5
T TR5/TR250 Question on Lucas Hazard relay Triumph 14
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
Patrick67BJ8 Lucas SLR Driving Lights installation Austin Healey 26
