TR4/4A Leveling the Valve Cover
CinneaghTR
I have a Justin Wagner gasket that I want to install and I have a valve cover that when pressed down on three corners has a 1/8" rise on the fourth. (I used a marble counter top as my guide and double checked against the work bench.)
Is that worth trying to knock down? If so, what is the best way. If it takes a body hammer, which one exactly? I probably should also look into a different surface to work from, too.
Thanks in advance!
Jeremy
dklawson
Marble and even faux stone countertops are usually pretty flat, flat enough for what you are doing. Generally, thick pieces of MDF also give a very flat surface for most purposes. EDIT: But nothing is more appropriate to use for checking the cover than the cylinder head itself.
If it is one corner that is up, you may find it is due to twist that you need to work out of the cover by clamping one edge down and then clamping a lever to the flange to twist it the "other way". If you RTV the gasket to the valve cover you can easily accommodate 0.010" or more waviness.
To compensate for the gaps, clean all gasket residue off the head and the seal track on the valve cover then degrease both.
Spread a thin coat of grease on the top of the cylinder head where the gasket will sit, then press the new gasket firmly down against the head.
Apply RTV to the gasket track on the valve cover, a thin continuous bead.
Lower the valve cover onto the gasket and tighten the hardware finger tight to hold the cover down in place.
Allow over night for the RTV to cure, then tighten the cover completely.
The grease will hold the new gasket down flat against the head and provide a release when taking the valve cover off.
The RTV will both bond the gasket to the cover and fill all the waviness and voids to the valve cover seal track.
It takes a bit more time to do it this way but it provides an excellent seal, requires very low torque to achieve a seal, and the valve cover is removable multiple times for service.
Kleykamp
If you have the original chrome valve cover, it is probably warped from the nuts being tightened too tight on the studs. Those are almost always overtightened. If you hammer and dolly,lightly, around the two holes on top it may release the pressure pulling up the corner. I would think the gasket should close up a gap that small anyway. Just a suggestion.
poolboy
I agree with the twist concept by Doug, but if it's the same type of gasket that Wagner made for the TR6 valve cover, I don't think you'll be able to use RTV or anything other than glue between the gasket and valve cover.
HerronScott
Hi Jeremy,
Glad to see that you are still around! I was just thinking that it's been a while since I've seen a post from you.
Scott
CJD
Chrome doesn't respond well to beatings. I frequently use a liberal bead of silicone on the rim of the cover, and then press the cover down over the gasket while on a flat surface. This has 2 benefits...the gasket surface is now perfectly flat, and the gaskets stays stuck to the cover for valve adustments. Same results as Doug...just a little different twist to get there.
CinneaghTR
CinneaghTR
Thanks for the kind note, Scott. I've been lurking off and on due to work and our 16-month old daughter, Piper, but I've been finding time to tinker lately. That means I need to pose questions for the great folks on the BCF!
All the best and talk to you soon!
Hi Jeremy,
Scott
HarryL
Well; here's my take on it.
I use the plain old cork gasket, soak it in water til wet,
yellow snot to keep it on the valve cover,
lightly tighten it down, come back after a couple of beers
and tighten it down completely. Same goes for the oil pan.
Harry
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
A T-Series MGTD oil pump bypass valve MG 0
S Price check on TR3A valve cover Triumph Classifieds 0
H BJ8 Heater Valve/Control Tap Austin Healey 3
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
G Valve adjustment and easiest way set cam position Austin Healey 15
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
dbenichou289 TR2/3/3A Valve seats Triumph 8
steveg TR6 Adding a PCV valve Triumph 5
D TR6 Valve cover paint Triumph 5
B TR4/4A New valve gears/timing Triumph 21
