Last Year Minis were imported
RCL
Member
This may sound stupid for a mini owner, but I have two questions...which dozens of "experts" have given me a dozen answers. Here goes: WHat was the last year British Leyland exported Minis to the U.S. ? What was the last model year the U.S. Government grandfathered/allowed Minis into the U.S.????
[ 08-18-2003: Message edited by: RCL ]</p>
Xracer
"WHat was the last year British Leyland exported Minis to the U.S."
1967. Some were sold in '68 as leftover '67s. BTW, it was still BMC back then. All of them were badged as Austin or Morris. Didn't become BL until about '71.
"What was the last model year the U.S. Government grandfathered/allowed Minis into the U.S.????"
1978, under the current 25-year exemption. Cars over 25 years old may be imported without having to meet the then, or current, EPA and DOT standards.
In other words, you can import (and many people do) any Mini that is titled as being 25 years old or older.
R
RCL
Member
Thanks Xracer.....someone tried to convince me at a hill climb this past weekend that a 71'...namely mine...was imported illegally. I thought BMC brought them in till 76 or so...I also heard some Canadian cars were brought in as late as 82' ..legally, that is.
Thanks for keeping me straight with the history lesson.
Xracer
Yep......Minis were imported into Canada until about '78 or '79.
If yours is a '71 and left hand drive, it was originally a Canadian car, and unless it was a rare Mk.III Cooper "S", it was a Mk.III Leyland Mini 1000 (998cc engine).....however, '71 was transitional between BMC and Leyland, so some '71s and '72s might be badged as Austin or Morris.
It should have roll-up windows, and no external hinges, and, if original, a 998 engine.
[ 08-20-2003: Message edited by: Xracer ]</p>
Sherlock
Mostly true...
British Leyland sold Mini's brand new in Canada up to 1980, by then only with the 998 engine, many have since had the BMC 1275 installed. There is a hot market up here for the 1970's Mini's, look up almost any Canadian classfieds listing and they are regularly listed for healthy prices.
Import rules... A car has to 25 years or older to be legally exported into the States, 15 years or older to be legally imported in Canada. As a result there are piles of the 1980's Rover Mini's being imported into Canada right now.
R
RCL
Member
Thanks to both Xracer and Sherlock......
Bought my 71' with B.L. number plates in S.C. and had it "fixed-up" in Texas. Left-hand drive, BMC 1275 installed ...has roll-ups, newer doors (no hinges...inside door handle is mounted at slight angle- not quite 45 degrees... so it may have come by way of Canada.
Glad they are keeping the prices up in the North...makes me feeel better about spending sooo much mooola to restore and fix up ours
RCL
Xracer
Thanks Sherlock. I wasn't sure of the sales cutoff date north of the border. I knew it was somewhere around that date.
Yeah, the 1275 engine swap was, and is, fairly common for the Mk. IIIs....as well as the conversion to 7.5 disc brakes. We've got several Cooper "S" clones in our club.
Still, in all, the stock Mk.III with the 1000 engine makes a nice, (fairly) reliable road Mini, and the twin leading-shoe brakes are at least adequate.
Sherlock
Because there are so many Mini's all over Canada(most of them the 1970's ones that were sold here new) there are lots of clubs devoted to them.
In our club (below in signature) among other saloons there are almost 100 Mini's represented and I know of at least two other all-Mini clubs in southern Ontario, and more all-Mini clubs across the country.
For a good Canadian Mini website that will give you an idea of the scene up here go to www.miniportal.ca, there is a definite advantage up here for Mini fans because there are lots of the 1970's examples left.
R
RCL
Member
Thanks Sherlock... WOW, I never knew ther were sooo many minis in Canada. Sounds like that's the place to be.
Where is Barrie.... I did some work in the Brampton are...and my wife and I honeymooned in Canada....23 years ago!
RCL
R
RCL
Member
Sherlock...forgot to add....What are the BIG events for Minis in Ca...and when do they happen (sounds like a vacation plan in the works...ha ha ha)!
RCL
Sherlock
Hi RCL,
Barrie is about an hour north or so north of Toronto, although I'm only going to be living there until the end of September at which point, after about a week of driving and checking out neat British/import cars, I'll be in Calgary.
As for Mini events, you should try to make an effort to come up for British Car Day in Oakville/Burlington coming up on September 21st (or at least the Sunday closest to that date!) There will likely be around 75 Mini's on display, along with over 1,000 other British cars! The whole details are posted under the Local Events forum.
Aside from that show there are some Mini-only events that take place in Ontario earlier in the summer, there's a website somewhere that likely lists them.
Maybe see you there... it will be my last Ontario Brit car event before I move.
[ 08-23-2003: Message edited by: Sherlock ]</p>
Xracer
RCL....this year was a BIG year for Canadian Mini events:
June 5-8: Back To The Bay for Rendezvous 2003 in Thunder Bay, Ontario put on by the Thunder Bay Vintage Sports Car Club...lots of Minis attended.
July 1-4: Mini Meet East in Magog, Quebec
August 8-10: Crazy Canadian Mini Jamboree in McGregor, Ontario
August 11-15: Mini Meet West in Victoria, British Columbia
....and, of course, the Sept. 14th British Car Day that Sherlock mentioned.
Sherlock.....where are you moving to?
Sherlock
One slight correction... the Toronto Triumph Club moved weekends (for British Car Day) on me, it has always been the second weekend after Labour Day long weekend up here, well... until this year apparently the new date is September 21st - off to Local Events forum to change the date.
If you read my new updated profile it's back home to the "real" mountains of Alberta in a few weeks. I'll miss the plethora of Brit/import cars all over southern Ontario but I've been waiting for too long to get back to the mountains (and there are actually a fair number of Brit/import cars around Calgary too, so it's not a complete washout)
aeronca65t Saw lots of Minis last weekend British Motor Corp 1
Hamish Racing General TR At last a New Triumph Triumph 2
Got_All_4 TR6 TR6 Down Pipe How They Last Triumph 6
D Removing the last rust from pitted steel Restoration & Tools 11
steveg At last - inexpensive double crimp tool Restoration & Tools 4
CJD General TR Parts Just Don't Last Anymore Triumph 6
KVH TR4/4A One Last Light Problem in my Restoration Triumph 13
P T-Series Where's my last TD? MG 2
Trevor Jessie When was the last time you bled your brakes? Spridgets 4
D Lilly running #3 / since last we talked.... Austin Healey 7
S TR2/3/3A got this with my last project car Triumph 2
V Last few months in the UK Pictures TVR 5
T TR2/3/3A Is there a timing cover seal that will last more than a couple of year? Triumph 23
V Darling Buds show last weekend TVR 1
L At last 1:18. Scale 100S becoming available Austin Healey 2
HealeyRick Last Big Healey? Austin Healey 20
glemon Last BJ8 in the US? Austin Healey 6
Scot1966 TR2/3/3A Last ride of the year Triumph 6
leecreek Last Projects by 2091351 Spridgets 5
K TR2/3/3A How long should an SU damper top up last? Triumph 22
JPSmit Hyundai Stellar - when last did you see one? Other Cars 6
Tom74TR6 Off Topic Caffeine and Carburetors - Sunday Oct 18 - New Canaan CT - Last one of the year Triumph 1
R Last minute check before engine install Austin Healey 26
Rut MGB Last little bit MG 0
G TR6 Last CR TR6 Triumph 2
GTP1960 TR2/3/3A How long do leaf springs last? Triumph 8
drooartz Sold my last bike yesterday :[ British Motorbikes 8
David Townsend General MG Last of the MG TD and MGC Engine Prints MG 0
David Townsend General TR Last Call for Holiday Print Orders Triumph 6
britlover Nice fall drive in the BN1 last week Austin Healey 7
Boink Last Midget Made Spridgets 10
PC last couple of days Spotted 2
sd80mac7204 Spitfire Road trip to help a friend last weekend with surprising results Triumph 4
catfood Saw five iteresting vehicles on the way home last night.. Spotted 3
Johnny AH BJ8 seen on "Madmen" last Sunday Austin Healey 3
aeronca65t Last 12 Minutes of the Bathurst 12 Hour Racing 0
L The last cast iron 6 port head Austin Healey 9
angelfj1 General TR last run with the lady Triumph 19
John_Mc Pre-War Pre-war gathering in Banff, Canada last Sunday... Triumph 7
JPSmit Cruise Night last Night Spotted 5
aeronca65t Random cars in our hotel lot last night Spotted 4
Mickey Richaud Last Thursday Spotted 0
JPSmit When did you last see one? Spotted 57
MadMarx Memories of the last Nordschleife race with open top cars.... Triumph 4
J Last Step, Rear end: What is this one? Austin Healey 8
mcguijo Some progress at last Triumph 2
Morris AT LAST! Spridgets 8
JPSmit Dropped off the engine for the Vauxhall last week Spotted 3
J Went to a Jensen show this last weekend Other Cars 10
A TR2/3/3A TR-3A Apron letter at last Triumph 3
