If my sports car mechanic--right out of England--back in '69 only knew that I'd have an online course available like this 40 years later . . . . How the world changes, but with some good things still here to enjoy.
Questions/Comments:
1) OK, now, when I put all this back together, do I need to blow out or somehow clean that galley that runs from the accumulator piston bore to the operating piston bores?
2) When I pulled the rear bearing I found a piece of hardened plastic of some kind, but no evidence of my shattered planet assembly bushing. I assume it dripped out in prior fluid changes.
3) That front bearing the shaft is a bear to remove. On my way to HF for a tool. I'll check end float, then yank them back out if need be. The only distance washer here is the one forward of the rear bearing.
4) The Buckeye articles show the annulus bearings being pressed in. I believe the TR manual speaks of drifting the bearings in place (but I'll have to check).
Thanks for all the patience and help guys.
Questions/Comments:
