I'm really getting close, but the machine shop has an issue.
The heat trick worked great to remove the speedometer bushing from the OD case in my TR4A. However, there is a small threaded insert that screws into the bushing, and that insert holds the fitting for the speedometer cable.
To prevent this threaded insert part from loosening, and maybe to set some mandatory end float, that threaded part was "pinned" just a bit shy of being tight into the bushing.
Can anyone tell me why it has to be pinned, because my pin broke and I'm wondering (as is the shop) if we really need to have it re-pinned.
This pin is not shown in the drawing below, but it is a component of part 95.
Thanks for the help.
