I think you're correct Randall about there being no interference, but the pistons must move more than that I would think. The brake ring is on the opposite side of the housing, and the pistons have to move that sliding cone clutch forward and off the brake ring, right?
I was guessing that's why the adapter plate has depressions that align with the nuts that hold the bridge pieces, and also why the manual suggests that the safety wire be away from those depressions.
Also, for whatever value at this point, my sun gear end float "after" installing the thrust washer in the planet gear was .019, larger than it should have been (.008 to .014). With that thrust washer missing, as it had been, my end float must have been huge.
By installing a new thrust washer in the casing, as well, I now have the end float down to .013, which can only be explained by the new casing washer being thicker. I assume wear and tear on brass made the old one thinner over time.
I also have new thrust washer I can put below the roller clutch. If I do that I assume I'll have even less end float?
Well, I'm about ready to roll! Thanks again.
PS One of the crisp new thrust washers I have is "thicker" where each oil groove has been scored. Swelling of the metal from stamping, I assume some filing is in order.
