How to test overdrive throttle switch and need arm
chuck1006
Hi,
I have a throttle swith for my 100-6 overdrive but am not sure how to test. I put the olm meater on and turn the rod. It goes from open to closed but should there be a gradual increase? I also don't have the arm or lever for it. Any ideas where to get?
Thanks
Chuck
5
57_BN4
Hi Chuck,
The throttle switch is just a switch, it should go from closed somewhere about the rest position to open either side of that point. Pretty basic inside, just a cam on the shaft and a set of contacts that are opened whenever the cam is not in the rest position.
Here's mine that I screwdrivered open the other day.
Andy.
C
chuck1006
Thanks Andy...based on that, mine seems to work fine. Now if I can just find the arm and linkage that goes on it.
Regards,
Chuck
John_Progess
Chuck,
I have an extra switch and you are welcome to the arm. I don't have an extra link but I think I can make one quickly. I live in Sale Lake so postage to Phoenix should be small. Let me know and have a good day!
John
Keoke
Be sure and pack it in Ice or it will surely melt I just left Phoenix-----HOT!!!--- :whistle:
C
chuck1006
Thanks John,
I would appreciate getting the arm. I don't have any pictures showing how the link (rod) attaches from the arm to the throttle linkage. I checked some british car part sites and they have the arm and rod but not the part that connects to the throttle linkage. I will probably buy the aftermarket relay on Ebay. I am trying to gather all the parts now and then will pull the tranny to put in the overdrive mainshaft and install the overdrive. I have a few spare parts too in case you need something. By the link do you mean the rod that goes from the arm to the throttle?
Regards,
Chuck
C
chuck1006
Hey Keoke,
Try driving a Healey here in 110 degrees. Like a sauna...guaranteed to lose a few pounds each outing..I should to do it more often! Of course, it's a dry heat!
Regards,
Chuck
Healeysince59
Come down to Tucson. In August we do a "Mad Dogs and Englishmen Run" . 100 miles at 100 degrees. This year we had 12 LBCs and they all made it.
Marv J
C
chuck1006
Hi Marv J,
Sounds like a fun run. Would like to try that but don't have a trailer so, it would be 100 miles to Tucson, the 100 mile run and 100 miles back to Phoenix. Not sure I would like to do that in August but one never knows.
Regards,
Chuck
Ppfffttt!
My Healey was a daily driver for quite a few of the years I lived in Southern Louisiana. Oh sure, we only had 95-105* temperatures in the summer, but it wasn't a dry heat, we were saturated in 100% humidity too.
:wink:
Keoke
chuck1006 said:
Hey Keoke,--WOT!!
I should do it more often! -- Me too-- :laugh:
Oh Yeah!! CHUCK, then why was I wringing wet all the time except when I was dogging 1" hail stones.---Keoke :driving:--------- :laugh:
Regards,
Chuck
John_Progess
Chuck,
The linkage is made from 1/8" dia rod about 10.25" long with 90 deg. bends on both ends and a couple of "Z" bends in the middle to allow for clearance of the main throttle rod. On the part of the throttle system that is located above the transmission there is a lever that has a link from it to the main rod that goes from the firewall to the carbs. The throttle switch link attaches to this lever at approximately the same location as the link up to the main rod. Probably clear as mud but I can make you a switch link if you need one. Have a good day!
John
M Overdrive Pressure Test Austin Healey 2
KVH General TR Overdrive Pressure Test Triumph 17
T TR2/3/3A How do I test overdrive relay diode jumper? Triumph 2
S TR4/4A How to test Overdrive out of the car Triumph 45
S TR2/3/3A Test an overdrive trans. Triumph 6
S Spitfire 76 spitfire overdrive test question Triumph 5
T A type overdrive repair and test Triumph 9
petnatcar Compression Test Record Form Austin Healey 0
kodpkd Compression Test Results Austin Healey 1
RJS General TR Oil Pressure Gauge - Test Triumph 11
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
PAUL161 T-Series 5 Speed Road Test MG 25
Rob Glasgow First Test Austin Healey 6
K TR2/3/3A Test Triumph 0
glemon Test FORUM Navigation Questions 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY Compression test results Austin Healey 17
HealeyPassion EFI AH Initial Test Day... Austin Healey 6
Michael Oritt Every ride is a test ride Austin Healey 9
roscoe Leakdown test [long read] Austin Healey 11
Y Passing the smog test MG 17
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
D Test image post FORUM Navigation Questions 1
D Lilly test runs Austin Healey 4
F TR2/3/3A Compression Test Triumph 13
M Carb emission test Austin Healey 5
RJS General TR Head Gasket Test Fit Triumph 5
Tinkerman TR2/3/3A SU H6 Rebuild Bench Test Triumph 3
KVH General Tech Leak Down Test Triumph 17
T TR2/3/3A SU Piston Drop Test Triumph 4
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
T TR2/3/3A 4th Test drive Triumph 12
P TR6 Latest compression test Triumph 11
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
gbtr6 TR6 Test starter system with engine out? Triumph 16
NutmegCT Memory test Other Cars 9
J TR6 Test 75 TR6 Hazard Switch? Triumph 12
T TR6 TR6 compression test Triumph 12
D LSR test run Racing 2
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
C High test or regular gas? Jaguar 4
C How to test shocks? Austin Healey 7
M Compression test results Austin Healey 11
NutmegCT TR2/3/3A Sports Cars Illustrated TR3 road test Triumph 17
J MGB Smog test fail MG 11
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
Lukens TR2/3/3A Is there a subforum that I can send "test" posts? Triumph 3
NutmegCT General Tech Condenser test? Triumph 38
B test a wiper motor? Spridgets 13
