Memory test
NutmegCT
OK guys - can anyone identify this engine - and the car it powered?
Hint: the car came stock with 2-speed Powerglide transmission.
eek
trrdster2000
I'll go with early Corvette. About the same time I tried a TR2.
Wayne
waltesefalcon
I've built a couple of these, the steering tends to be about as impressive as the drive train.
trrdster2000
I hated the babbet (SP) bearing, never did understand why Chevy stayed with them so long.
Wayne
pdplot
Stovebolt six. Memory test - what did the Chevy's of the late 40s and early 50s have concerning their 3-speed column shifts? I can still hear the gear whine of those transmissions.I never owned one but drove several.
PAUL161
Vacuum assisted shift! Hard to speed shift in the Summer and impossible in the Winter! I've owned 3 with that setup. But, that old cast iron 6 was one tough motor! PJ
NutmegCT
NutmegCT
Paul- how'd that vacuum assist work? What did it do? Automatic clutch? or power assist to moving the shift lever? or ...?
I'm a nut on finding out how the old tech worked. Maybe that's why I volunteer at Old Sturbridge Village!
PAUL161
Power assist on the shift. I never could figure out why it was invented! It worked great when new, but when it got a couple years on it, it was a royal pain as it took more pressure to shift than without it. It could be removed and return the transmission to a regular shift by removing the chamber and changing the linkages, which a lot of them were. :encouragement:
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
Bayless Memory block Spridgets 3
PeterK General TR Timely memory of a time capsule left in my 3A Triumph 19
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
Rut Help a bad memory out... Spridgets 6
GTP1960 Drive down memory road. Other Cars 14
F Sharing Memory Lane in an Austin Healey Austin Healey 7
PAUL161 Happy/Sad Memory, My Old Austin Other British Cars 2
Nelson Senior memory aid Spridgets 12
Morris Refresh my memory... Spridgets 5
K Memory Refresh:What oil to use after break-in? Triumph 1
K SU Mix Adjust Memory Refresh Triumph 7
10musketeer Clutch Peddle Box- Refresh my memory Spridgets 7
B A sad memory of a fellow Midget Owner. Spridgets 5
jlaird Someone jog my old memory Spridgets 20
Cain Stereo Memory Wire/Speakers Triumph 4
petnatcar Compression Test Record Form Austin Healey 0
kodpkd Compression Test Results Austin Healey 1
M Overdrive Pressure Test Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
PAUL161 T-Series 5 Speed Road Test MG 25
Rob Glasgow First Test Austin Healey 6
K TR2/3/3A Test Triumph 0
glemon Test FORUM Navigation Questions 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY Compression test results Austin Healey 17
HealeyPassion EFI AH Initial Test Day... Austin Healey 6
Michael Oritt Every ride is a test ride Austin Healey 9
roscoe Leakdown test [long read] Austin Healey 11
Y Passing the smog test MG 17
KVH General TR Overdrive Pressure Test Triumph 17
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
D Test image post FORUM Navigation Questions 1
D Lilly test runs Austin Healey 4
F TR2/3/3A Compression Test Triumph 13
M Carb emission test Austin Healey 5
RJS General TR Head Gasket Test Fit Triumph 5
Tinkerman TR2/3/3A SU H6 Rebuild Bench Test Triumph 3
KVH General Tech Leak Down Test Triumph 17
T TR2/3/3A How do I test overdrive relay diode jumper? Triumph 2
T TR2/3/3A SU Piston Drop Test Triumph 4
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
T TR2/3/3A 4th Test drive Triumph 12
S TR4/4A How to test Overdrive out of the car Triumph 45
P TR6 Latest compression test Triumph 11
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
gbtr6 TR6 Test starter system with engine out? Triumph 16
