Hood header rail gasket
bthompson
Well, I finally got around to it and replaced the hood on Nigel! Once the seams started dry-rotting, no amount of patching and re-sewing would save it. (Sorry, no pics yet; my niece has my camera this week) The new one went on like a dream, looks fabulous, this one will <span style="font-style: italic">actually </span>seal around the windows, and (drum roll) it has a zip out rear window! I'm happy as a clam. :banana:
One problem I always had with the old top was getting the header rail to latch. The driver's side would lock, but there was no WAY the passenger side would draw down. It was interfering somewhere at the right front edge; but it sealed all the way across, so I lived with it.
When I got the new top on, I found it would lock easily -- <span style="font-style: italic">without </span>the weatherstrip in place. It looks like there's only an eighth of an inch of clearance between the windshield and the rivet strip on the header rail. <span style="font-style: italic">Far </span>too little space for the big ol' mushroom gasket that was on there before, it seems. No wonder it wouldn't latch!
Anyway, can someone shoot me a quick pic or description of what the <span style="font-style: italic">proper </span>gasket looks like? If I have a wonky gasket it would explain a lot. When I get my camera back I'll post some pics of what's happening.
Billm
I am going to guess that your clamps are not adjusted correctly-
If you look at the screws behind the clamps you will see two 5/16 head screws that are in slots.
If you loosen the screws some you will see that both clamps will work- then you can adjust them to clamp properly.
BillM
bthompson
bthompson
Good guess, Bill...but the clamps are adjusted all the way down already. With the weatherstrip out, there's a little slack to pull the adjustment up, but not much at all. The clamps, even down as far as they can go, still latch fairly firmly.
Jer
bthompson
bthompson
Nope, the #16 header pads are original. The bows are in good shape. When the hood was off I took a good look at the mating surfaces. Even with the pads and weatherstrip off, and clamps adjusted all the way down, the front of the rail touches the windscreen. With pads or without doesn't affect my clearance.
More tellingly, it doesn't look like Moss #12 matches my weatherstrip profile. If it was a low rectangle in profile like that, it might work with my top. Mine is a hollow mushroom in profile; just looks like too much stuff to squeeze down to me. Does yours look like that?
bthompson
bthompson
Oh, hooray! We've had torrential thunderstorms all night down here: Nigel's waterproof trial-by-fire. Even with no front weatherstrip installed on the header, this morning there was no water inside, no water in the trunk. None at all! Nothing getting by the windows or in the front corners. I may just use a cheapo adhesive foam strip now to cover the rivet strip.
The zipdown rear window is a great invention: I'm going to love driving this summer. The bulk of the zipper makes folding the top in the traditional manner a little tricky: I'm using a different method to fold it that I've found works well, but is a little fussier. (Pics will follow, in another thread.)
RickB
I have the zip down rear window and I fold my top like this:
Detach of course first from the front and sides
Pull frame back about 3/4 way down
Pull top back and lay on trunk folded in half, there seems to be a natural halfway point there
Fold corner window triangles under, this protects the windows
Pull frame rest of way down
Make sure front catches are in safe position, not sticking up
Wrap top over frame and down into parcel area
Install top boot
Putting it up is the reverse.
bthompson
bthompson
That's how I used to do it. It seems with my new ziptop, the reinforcement and bulk around the zip makes it difficult to fold the corners in, without the fold being uncomfortably close to the corner window weld seams. Could just be that the top is still new, maybe I'm just a little bit of a nervous nellie with a brand new top with crystal clear windows!
The method I'm trying is to unzip the back window and let it down first, so the bows fold down in front of it. Instead of laying the top across the trunk, lay it forward over the seats, with the side windows folded in along the zip, then fold the top back in thirds so it sits on top of the bows, instead of wrapping around them. (Basically, this mimicks the way it was folded in the box for shipping: there are natural fold points) Roll the rear window up and tuck it up inside the bottom of the top boot. It seems to keep all the plastic safe, doesn't put any folding stress on the windows or zippers, doesn't put any twisting stress on the front window surrounds, and looks kinda cool when it's folded up too. :thumbsup:
Jim_Gruber
Pics needed having trouble understanding how this is different than the way I fold it.
bthompson
bthompson
Pics aplenty will be forthcoming. Just gotta wait for my niece to mail my camera back to me first. :rolleyes:
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
S TR2/3/3A 59 TR 3 hood emblem Triumph 2
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
R New Hood for BJ7 Austin Healey 3
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
S TR2/3/3A Hood Stick Cover Triumph 3
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
B BJ8 Hood Bow and Seal Austin Healey 5
B Hood Woodwork Austin Healey 2
Papajack TR2/3/3A TR3 Hood and Sidescreen Colors Triumph 6
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
R TR6 Stronger hood release? Triumph 4
MGTF1250Dave T-Series Hood Sticks MG 4
TomMull Wanted Herald Hood Frame Triumph Classifieds 9
TomMull Convertible hood frame Other British Cars 3
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
S Forward opening hood / bonnet Spridgets 10
D BJ7 Hood frame mounting plate Austin Healey 7
S TR2/3/3A Tr2 hood Triumph 8
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
steveg TR6 Hood release pictures needed Triumph 22
HealeyPassion Hood scope chrome gap fix ... Austin Healey 0
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
S Pre-War my hood problem got worse! Triumph 6
S TR2/3/3A The chrome beading is rubbing on the hood Triumph 5
G Wanted WTB TR3 Hood Hardware Triumph Classifieds 0
B TR6 TR6 Hood Release Cable Triumph 7
A TR2/3/3A how do i fix this hood line? Triumph 5
Z For Sale 1956 Austin Healey BN2 Factory hood Austin Healey Classifieds 0
L TR2/3/3A Hood / bonnet plinths Triumph 12
TomMull Wanted Triumph Herald Hood Finishers Triumph Classifieds 3
D TR2/3/3A Fitting the hood. Soft top. Triumph 6
J TR2/3/3A Hood oilcanning Triumph 6
anarchy99 Bonnet / hood fit question... Spridgets 2
anarchy99 Wanted WTB: 64-66 sprite hood in decent shape. Spridgets Classified 2
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
K TR2/3/3A Location of Hood[Bonnet] Louvres on a TR3A? Triumph 1
L Wanted 100/6 Longbridge hood parts Austin Healey Classifieds 3
L 100/6 Hood parts Austin Healey 11
britlover Wanted TR4 Hood long bubble Triumph Classifieds 0
4tecdog Windscreen rail to hood seal Austin Healey 11
G Fixings for liner assembly hood comparment -BJ7 Austin Healey 7
Keith_M bugeye front tilt hood fastener -- choices Spridgets 9
D TR2/3/3A Under hood Photos Triumph 7
4tecdog Modify frog hood frame Spridgets 12
