Woodie
Ok I am investigating my hazards lights, they have never worked. I am using the wiring diagram here wiring diagram The two brown wires on the solenoid switch #4 should both have power all the time correct?
On the solenoid switch in my car the terminal to the key (brown wire) has power all the time. The Other brown wire (to the hazard switch in the console) at the solenoid does not. The solenoid has one lug coming off the power post while the other brown wire is coming off a lug directly opposite the red white wire that goes to the ignition key switch.
When I ran a jumper from the ignition brown to the hazard switch they work.
So two and a half questions,, is the solenoid the right one,, does it matter, can I just jumper the wire to make it work?
