Gear ratio and tracks to run on?
VelodromeRacer
While we are discussing the fuel MPG, I wondered what gears are better for the different tracks? For that matter, what gears a 948 Bugeye should run most of the time.....
My Bugeye currently has the 4:22 installed and VSCDA runs at Blackhawk, Grattan, Gingerman, Road America and Mid Ohio..I have a 4:55 sitting in a box. I don't have the skills to change out gears all the time and wondered what would be the best scenario?
Bugeye58
Blackhawk 4.55
Grattan & Gingerman 4.22
Mid O & Elkhart 4.22 if it's all you have, but a 3.90 would work better at Mid O, and a 3.7 for Elkhart. With a 4.22 at Elkhart, you're going to be wound tight over a good portion of the 4 miles.
If you can make it over to play with us at Waterford, the 4.55. I run a 4.88 here.
No major skills involved in a gear change on a Sprite. You just change the entire center section. About a 45 minute job.
Jeff
VelodromeRacer
VelodromeRacer
Bugeye58,
Is there a good link to how to do it? I thought it involved some pretty technical settings, shims and axel removals?
Bugeye58
Ah..you just have the gears, not the entire assembly. That's a different story entirely.
The manuals show a pretty good procedure, but there are some special tools required to do it properly.
I just have the entire differentials, and swap them out as needed.
Axle removal is a piece of cake. You just remove the wheel and brake drum, pull the retaining screw from the flange and slide the axle out.
I think I'd check around and try to find entire pumpkins in the appropriate ratios, or consider outsourcing the setup, perhaps to Hap Waldrop.
If you're going to be running different tracks requiring different ratios, it's the only way to go, rather than trying to swap gears back and forth in the same carrier.
Jeff
Hedgehog
VeloDrome,
We were running the 4.2 at RA in our 948 Sprite. We ran 4.5 at Blackhawk. We never tried a 3.9 at RA, but I think it would be a better choice than the 4.2.
If you need full pumpkins give me a shout. I may one or two.
VelodromeRacer
VelodromeRacer
The car also came with a Quaife ATB Differential...?
Should that be used...?
Bugeye58
I sure as heck would be using it!! /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
I've got a Trannex in mine.
Have you priced a Quaife lately? Sit down when you do.
Jeff
VelodromeRacer
VelodromeRacer
I figured for the price that I saw...that it should do more than sit in a box! The car I bought came with the 4:22 unit installed and a 4:55 gearset and a box with the Quaife unit in it. Do I buy another pumpkin to put the Quaife unit in? When you are talking about ease of installation, are you talking about installing the pumpkin unit into the existing housing? Is there a good reference for the install instructions?
I just don't want to screw this up, and knowing that I will be running different tracks, I feel I need to work on this over the winter.
At Putnam Park, I down the long front straight, I was hitting 7,000rpm and running out of gear/speed...
Bugeye58
As for swapping pumpkins, it's only a matter of sliding the axle shafts out of the way, disconnecting the driveshaft, undoing the mount bolts and brake union bolt, and pulling it out. Installation is reverse of removal.
At only 7000 rpm you should have at least another 1500 to go, if the engine has been built correctly.
You may want to contact Hap for further advice regarding setting up the Quaiffe.
Jeff
Deleted member 3577
PITA having to add 'slip juice'...
How do you like it?
A bit smoother than the Quaife....
Especially noticeable from apex to track-out (power on)
(But you 'lincoln-locker' road race guys, probably wouldn't notice unless yer coming out of a hairpin)
Noisy though when cold & sometimes at turn-in, the back end doesn't settle right away.
Bugeye58
Dave, I like the Trannex. Definitely smoother than the Quaife, and seems more forgiving if the power application is a bit abrupt.
I dread having to ever being forced to run a welded diff. again. Not that it's going to happen, but if something breaks and the only spare I've got is a welded one..........
Jeff
Michael Oritt
In the Elva I run a 4.5 at Pittsburgh and Shenandoah, a 3.9 at Sebring and a 4.2 everywhere else. Changing the diff takes me about one hour when I am motivated.
VelodromeRacer
VelodromeRacer
I may have to try and look for a 3.9 then I will have a whole collection!
Taylor-racing has a rebuilt ribcase with straight gears and a changable drop in 4th gear...anyone have something similar?
You have a Taylor dog box???? That's like a $5500 gear box, I have one, it's the best money will buy, this gear box depending on your gear selection will let you use first gear on the race track, does this gearbox have a hydraulic throw out bearing????
No not a Rocket Box, that is the 4 speed version of the Quaife, often times used in MGBs, but other applications as well. Craig Taylor used to rebuild alot of the Richmond RIC Spridget gearboxes, then went on tho make his own version of it, it's basically a Spidget case, modified to accept Webster/Hewland gears, pretty much umlimited gear ratio selections, they are pretty popular with the Spridget racers, go to https://www.taylor-race.com then select catalog, then select transmission, then select Sprite, then then click on the blue part description, and a pop up windw will appear and tell you all about the gearbox.
My Taylor dog box has 1.60 1st, 1.36 2nd, 1.15 third, and 1 to 1 forth. I only drop about 300 rpm between shifts, You can set them up to run a zillion different ratios, and it has a 4th drop gear so you can change just that and that will end up changing the remaining ratios as well. They have all new main shafts, and layshafts made form the best metals, billet steel adjustable shift forks, custom front cover, and either SABB 900 or Tilton hydraulic throw out bearings, thay are top notch gearboxes.
Well in the sense of the Formula Fords using the same gears, yes, but they were never used production transmissions, in fact the gear box casing used in formula Fords came from the VW Beatles. Alot of different production gearboxes in race prep have ended up using Webster/Hewland gears because there are so many choices for ratios, I seen Spitfire, Alfa, etc. box upftted for use of these gears, Spridet boxes being one of the most popular. Now here's a newsflash, I'm pretty tight with the guys at Taylor Race Engineering, would you believe more of their Sprite racing gearboxes have been sold to vintage customers than SCCA customers.
VelodromeRacer
VelodromeRacer
Hap,
Do the vintage guys frown on the Taylor box...or do they allow it as the original smoothcase boxes are gone and the ribcase units fail in racing too easily?
Deleted member 3577
I know the VSCCA guys would have a kitten...
They'd probably make the offender eat Velveeta & drink wine out of a box.
I Correct ring and pinion gear ratio for Bugeye? Spridgets 5
PAUL161 MGA Doc, Do You Know MGAs final gear ratio? MG 11
AUSMHLY Gear ratio in Rear End Austin Healey 13
John Moore Diff Gear Ratio Spridgets 25
prb51 Gear ratio/speed conversion Triumph 0
Webb Sledge 1st Gear Ratio on a Healey Hundred Austin Healey 2
L T-Series Gear box servicing cap. MG 5
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
Todd78d Sprit MK1 gear box filler Spridgets 2
B Transmission Gear Lockouts Austin Healey 8
S Gear Shift Lever Travel Austin Healey 13
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
S For Sale Differentail gear sets available. Spridget, Morris Spridgets Classified 12
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
C Spitfire gear selection Triumph 10
JPSmit Gear reduction starters anyone? Restoration & Tools 5
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
AUSMHLY Remanufactured Laygear with welded 1st gear Austin Healey 20
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY First Gear Sliding Hub Endplay Austin Healey 1
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
DocDup1 TR4/4A Second Gear Bushing Triumph 6
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
S TR2/3/3A Gear shift knob Triumph 8
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
AUSMHLY BJ8 Gear Shifting Austin Healey 5
R Bugeye reverse gear Spridgets 6
TomMull TR2/3/3A 1st gear again Triumph 3
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KVH General Tech Gear Shift Sticks Triumph 6
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
D Socket for TR3 Gear box drain plug Restoration & Tools 6
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Jim_Stevens TR2/3/3A Ring gear shot? Triumph 26
