Front end alignment
reavestr6
I just had the front end of my newly restored TR6 aligned and the front wheels have a noticeable tilt in at the top.They nearly mirror the rear wheels,which I expect to see this on.I replaced all the front end suspension components during the rebuild.Should this be this way?Any input would be appreciated. <font color="blue"> </font> /ubbthreads/images/graemlins/confused.gif
Simon TR4a
Your workshop manual will give the correct camber specs, perhaps also the owners manual. This is referred to as "negative camber". From memory I think you should have zero camber on the front wheels, with up to 1 degree negative or 1/2 degree either way acceptable.
Make sure the steering is straight and wheel the car several feet on a flat surface to be sure your impression is correct; sometimes looks odd after jacking or turning.
Simon.
MDCanaday
Camber of the neg type is easily corrected but I am puzzled by this just appearing out of nowhere. just a simple re-build should never be able to do this.It could indicate a bent cross brace from some major collision or something very wrong with the way the upper control arms are done....
MD(mad dog)
X Front End Alignment Austin Healey 14
G Front end Alignment - Total Toe vs. Individual Toe Austin Healey 3
B TR2/3/3A Front end alignment Triumph 23
M front end alignment Austin Healey 12
T TR4/4A Front end alignment specs for lowered car Triumph 2
S TR2/3/3A Front end alignment and tire wear Triumph 9
K TR2/3/3A Using Moss front end alignment gauge? Triumph 6
O TR2/3/3A TR3 front End Alignment Triumph 8
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
S TR2/3/3A tr3 front end alignment Triumph 9
L Front end alignment Austin Healey 6
DrEntropy Anyone interested in DIY front-end alignment? Restoration & Tools 14
CraigLandrum TR2/3/3A TR3A Front End Alignment guru wanted Triumph 26
SCguy TR4/4A TR4 front end alignment Triumph 2
ronzet Speaking of front end alignment MG 20
G Front End Alignment Spridgets 41
PAUL161 Front End Alignment MG 8
bluemiata90 Brake shims/Rough front end alignment Triumph 4
M Spitfire Alignment on Spit Front End Triumph 6
G MGB '71 MGB Front End Rebuild MG 2
craigshealey3000 Front End Shake Austin Healey 31
B Bent frame rails near BE front end Spridgets 2
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
AUSMHLY BJ8 Front End Squeak Austin Healey 25
AUSMHLY 64 front end too high Austin Healey 14
thibault BJ8 plus 55mph Front end shaking Austin Healey 100
vette Effects of Lowering the Front End Austin Healey 21
R Front wheel bearing - end float Austin Healey 40
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
K TR2/3/3A Front end woes... Triumph 18
S Wedge tr8 front end Triumph 0
Jim_Gruber Bugsy IV Front End Rebuild Spridgets 5
mcmillal TR4/4A Front End Vibration Triumph 9
K TR2/3/3A Front end Question.... Triumph 4
Joe Reed MGB Rattle under front end? MG 8
J MGB Project car done; front end clunk noise while braking MG 4
aeronca65t Minor front end work Spridgets 12
RAC68 Calculating Front Hub End-Play Austin Healey 32
aeronca65t front end maintenance Spridgets 5
bugedd Front end rebuilt help Spridgets 6
BlueMax Front End Completed Spridgets 23
bugedd About to rebuild front end...any tips? Spridgets 5
K TR2/3/3A Front end reassembly: trunnion spindles and wishbone bushes??? Triumph 10
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
D XJ6 series III front end rattle Jaguar 5
Tr3aguy Front end rebuild questions>? Triumph 6
