TR6 Electrical Problem with TR6
TR3and6
Hello:
I am a new member and would like any help I can get on a current electrical Problem, 1976 TR6.
It started out with the rt. turn signal not illuminating. Checked bulbs, grounds,front and rear, etc.
Switch works as you can hear the flasher pulsating, but no light.
Found open wire on rt marker light reconnected.Noted Blown fuse (lower fuse). Installed new fuse (35 amp).
Upon connecting Battery,Lower fuse wires started smoking, did not blow fuse (35 amp).
Disconnected marker circuit.
Upon re-connecting Battery,Lower fuse wires started smoking again, did not blow fuse (35 amp).
Recently had to replace middle fuse (blown) when horn did not work. New fuse fixed that problem.
About 30 days ago I had to force unfreezing the Instrument rheostat.
This may have started #3 fuse problem as I did not notice lack of panel lights.
Any ideas?
Thanks
Got Message re: 35 amp fuse Thx MR
M_Pied_Lourd
Are they British Fuses for starters?
Cheers,
M. Pied Lourd
BobbyD
T
TR3and6
Hello
An update on my problem.
Resolved issue with dash illumination rheostat.
Isolated problem to apparently be with the Hazard switch.
When I pull the Hazard switch to on position the third (lowest) fuse blows. If switch is in the off position everything works except the original right turn signal.
Disconnected Hazard switch and attempted to connect the green lead to the green/white(Rt turn signal) and green/red (Lt turn signal). Result was the first fuse (top most blew).
The info on the wire chart and fuse ratings was most helpful.
I'm thinking the problem is with the Hazard switch (replace) but that's a costly and difficult operation re: dash board partial removal.
I am looking for ideas.
Thanks,
TR3and6
Gliderman8
I would not suspect the hazard switch since it is used very little. I would check to make sure it is wired correctly since you have the schematic.
It's also possible that you have a grounded circut casuing the fuse to blow.
Deleted member 8987
Like, the right turn signal feed is connected to the ground....or the socket is internally shorted.
Unplug the right turn signal wires, front and back, see if the hazard blows the fuse.
Turn hazard off.
Connect RF, try turn signals. If no light, unplug, and re-connect RR, see if you have signal there. That's a quick isolation.
T
TR3and6
Well
here I am again.
Still no luck with the Rt turn signal.
Pretty much tried everthing.
Zeroed in on Hazard Flasher. Replaced, albeit with 5 amp rather than 10 amp. Hazard lights worked even though the 5 amp flasher heated up, did not blow fuse.
Oddly enough, when I disconnected the front to back wiring harness and activatedthe the rt signal, front blinker lit up and stayed on, curious.
At this point every light works, even all the previously shorted out marker lights. Even soldered the rear right socket to improve conductivity. All grounds are good.
Bottom line, when I engage the Rt turn signal I clearly hear the flasher with a rapid beat, but no illumination.
Sigh.
Any new ideas out there.
Thanks
Bob
TR3driver
Great Pumpkin - R.I.P
So when you turn on the hazard flashers, is the RR light the same brightness as the LR?
I'm guessing that there is still a partial short in the RR lamp or the wiring to it. My next step might be to connect an ammeter (DMM set to 10 amp range) in place of the turn flasher, and compare what it reads between right and left. The lamps should come on solid of course, making it easier to read the steady current.
T
TR3and6
Well, suprise suprise
Randell was right.
I isolated the rt wire in the rear harness and connected an outside wire, totally isolating the wire. Lo and behold the rt signal worked.
Final solution. I cut the GW RT wire isolating it from any back feed and installed a parallel wire. Problem solved.
Hazard flasher also need to be replaced for $6 bucks. Minimum order from Moss is $10 bucks + &6 bucks shipping.
I will just wait on flasher.
Thanks again to Randell
Bob R
hondo402000 TR6 TR6 electrical problem continue Triumph 23
hondo402000 TR6 TR6 towed on Sat night, electrical problem Triumph 9
TR6Stuart TR6 TR6 Electrical Problem Triumph 10
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
B TR2/3/3A Electrical Problem Triumph 13
H Electrical problem I need to solve Spridgets 7
B TR2/3/3A Another Electrical Problem Triumph 2
Gerry M TR6 Another electrical problem Triumph 1
J TR6 Electrical ignition problem Triumph 9
5 TR2/3/3A TR3 electrical problem ignition or generator??? Triumph 12
B Electrical problem British Motor Corp 4
6 Electrical problem Austin Healey 10
D Coil and/or Tach Electrical Problem MG 8
Anthony_S Electrical problem Triumph 12
bigjones Interesting electrical problem Spridgets 9
1 Electrical/guage problem MG 8
kyreb1862 MGB 77 MGB Electrical Problem MG 16
kyreb1862 Electrical System Problem Need Help ASAP MG 7
J Electrical problem with flasher relay? Austin Healey 10
scott_74 Electrical Problem Spridgets 20
Got_All_4 TR2/3/3A TR3A Electrical and Missing Problem Triumph 8
M TR2/3/3A TR3 A Electrical problem Triumph 8
Thor How to troubleshoot this electrical problem Spridgets 14
A Electrical Problem Austin Healey 8
jjbunn Electrical problem: car wont start Triumph 23
J T-Series Electrical Problem: headlight switch turns starter MG 28
B Electrical problem / Fuel octane MG 12
G Spitfire Help with Spitfire electrical problem Triumph 13
1 Help on a bad problem, electrical, fuel? MG 12
Monark192 Solution to electrical problem MG 8
RSMTR8 Wedge TR8 Headlight/Electrical Problem Triumph 11
kyreb1862 Got a Whole New Electrical Problem MG 10
C electrical problem MG 2
Lin Electrical Problem Spridgets 5
Lin Electrical problem Austin Healey 6
Russ Austin Electrical Problem Triumph 4
mgbmedic Electrical Problem MG 7
T Electrical Problem MG 10
Y Electrical Problem MG 10
D Electrical problem [imagine that] Spridgets 9
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
N MGB Electrical Part Identification MG 3
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
