I need a little help getting started with solving this problem:
I am installing a new alternator in my son's Bugeye. We had a Lucas alternator in it before. I have just installed a mitsubishi unit. Had to do a little bracket work and the usual fitting, but in the end I was pleased with the effort.
I had a three prong plug on the Lucas alt. Big spade brown wire from the battery, two little ones - one for the brown/yellow wire that I think is the indicator warning light to the speedo, through the ignition I believe. I forget what the other small wire is, sourced from the no longer used voltage regulator.
On the mitsubishi alternator, the big brown wire (big spade connector) from the battery connects to a scew terminal on the back of the unit. The other two small wires from the Lucas plug were spliced into the Mitsubishi two prong plastic plug and plugged into the back of the alternator.
I then checked my battery -fully charged, and turned on the ignition. Got nothing, No fuel pump ticking, no fuel gauge jumping into action. I have spark to the alternator through the brown wire from the battery. The starter works fine. But, nothing at the ignition switch. No obvious lose wires and everything worked before the alternator change over. No blown fuses.
Can anyone help me with a troubleshooting plan of attack? Probably something silly or stupid that I overlooked.
Thanks.
Lin
1959 Bugeye
1960 BT7 in restoration
Thanks.
Lin
1959 Bugeye
