teddymcmur
My 1980 MGB has always run beautifully, at least for the 6 months I have owned it, however, today without warning while driving it, the radio stopped working, temp and fuel gauge stopped working and the windshield wipers stopped along with who know whatever else I didn't notice. The car continued to run fine until I got home. I turned it off but it would not start again - completely dead; however the clock and interior light continued to work. I hooked up a battery re-charger and it immediately started again. I do not have the equipment, nor the expertise, to check the charging system, but I did check the battery with a cheap store bought tester, and it indicated at least three of the cells are in dire need of re-charging. The battery appears to be very old - it came with the car. Also, while driving home, the aforesaid items which had previously stopped, came on and off again several times. After getting the car started, I drove it around the block several times and the same things stopped working again and shortly after that the car died while I was driving it.. I was able to jump start it to get it back home. Once home, I turned it off and it restarted.
New battery? Alternator. Any thoughts. I'm stumped.
Thanks.
Michael
Thanks.
Michael
