Hi,
I agree, pusher or puller is up to you. The pusher design is said to be a little less efficient, since it partially blocks air entering the rad from the front. One of the radiator manufacturers rates it as up to 20% less efficient, but sounds a little extreme to me.
Most rad manufacturers recommend a puller for maximum efficiency, but it's a more invloved project. Another reason for puller mounting is that a front/pusher mounted fan is more exposed to rain and road debris. On the other hand, the stock original fan, if left in place, will serve as a backup, if the electric pusher fan fails for any reason.
Some fans are puller only, others are pusher only. Some are reversible and can be used in either configuration.
Other considerations:
You'll probably wan to use a thermostat control for the fan. These can be non-variable type: usually come on at 185F and turn off at 170F. Or there are adjustable if you wish to play around with the temps where the fan comes on and turns off.
Some thermostats slip clamp onto the outside of a hose (not a great design), others slip inside a hose (better, but still not great). Others use a fitting that is installed in the center of a hose (still better, but adds two more possible leak points). And, others use a bung that's welded into existing steel piping (probably the best, but welding is required).
Front-mounted pusher fans are usually 10 or 12" diameter on TRs. That's enough in conjunction with the stock puller fan, and fits within the shrouding.
Rear-mounted puller fans are usually 12", but I've got 14" installed on my TR4 and have seen as large as 16". There is some overhang with 14 and 16", but they cover more of the radiator and move a lot more air. The 14" fan I've got is rated for up to a V6, 3500cc engine, about 1700 cfm if I recall correctly.
An important consideration is that any electric fan draws significant amps. Is your alternator up to it? Smaller fans draw less, larger fans draw more. Some of the larger fans draw a lot of power and will overpower most TR charging systems. Watch the amperage when shopping and keep in mind anything else on your car that draws significant power (halogen headlights, fog lights, elec. fuel pump, 1000 watt stereo, etc.).
There is not a lot of room for a fan behind the radiator, due to the crossbrace between the spring towers and the steering rack. It's possible to elongate the rad lower mounting holes and move it forward, but only a little. Measure the room available in your car and check this when shopping.
Most fans use a zip tie like arrangement that fastens the fan to the radiator. It's pretty cheesy. I agree, either rig a bracket (I did that too) or use J-bolts to hold it in place. The 14" fan mounting points were perfect for this. Don't know if that would be possible with smaller or larger fans, check mounting point measurements when shopping, if at all possible.
The big Triumph vendors charge a premium for fans, but sell ones that you pretty well can be assured will fit. However, these are off-the-shelf standard items and can be bought for a lot less at
www.summitracing.com or
www.jegs.com I bought mine from Summit, along with a fixed thermostat and wiring kit that included a relay and a self-resetting circuit breaker. It was Mr. Gasket brand and looks to be a good one.
If going with a puller and removing the stock fan, it's probably a good idea to leave the original fan hub in place. This is usually also a simple dampener for engine harmonic vibrations. I know this is critical on the 4-cylinder TRs, would guess it is on the 6-cylinder too.
Not applicable to your car, but on the 4-cylinder engines when a large puller fan and an alternator are being installed is an ideal time to do a so-called thin-belt conversion, including a proper harmonic dampener/pulley on the front of the crank.
Some like to add a switch for the fan in the cockpit, so it can be turned on when you wish. I didn't bother with this on my car.
Wiring the fan in, consider using a hot-all-the-time circuit. This will allow the fan to run briefly if needed, after the car is parked and turned off. Most modern cars are set up this way, so that the engine compartment can be cooled quickly.
Cheers!
Alan Myers
San Jose, Calif.
'62 TR4 CT17602L
