Dizzy without Vac Advance
karls59tr
Bronze
I've seen some brand new Pertonix dizzys that do not have vac advance. Is there any advantage to using this type of dizzy for a fast road car or slightly modified street car such as a TR3A with a mild steet cam and header?
JerryB
None for a street car.
You want vac advance to promote drivability, fuel milage and allowing the use of street gas.
D MGB 25D dizzy rebuild MG 29
tri_carb_healey Dizzy cap for petronix ignitor Austin Healey 8
weewillie can't tighten dizzy clamp Spridgets 3
drooartz Winter projects: carb and dizzy rebuild MG 26
DRKizer Pertronix Flame-Thrower "HP" dizzy for Brit cars Racing 6
bugedd Dizzy question Spridgets 9
DNK Dizzy part Triumph 4
drooartz Running top-entry dizzy cap on Sprite Spridgets 15
bighealeysource distributor lubrication knob on side of dizzy Austin Healey 3
Steve1970 What's the 3 wires below the dizzy, from the block Triumph 10
P CHECKING DIZZY CAP Spridgets 10
jlaird Miss Agathas Dizzy Spridgets 7
jlaird Dizzy off to Jeff Spridgets 6
tahoe healey dizzy follow up Austin Healey 7
Jim_Gruber Dizzy Question - Micro Adjustment Wheel 25D Dizzy Spridgets 7
tahoe healey Dizzy problem Austin Healey 5
tahoe healey Spark plug connector and dizzy repair Austin Healey 2
equiprx I keep gettting a wet dizzy. Jaguar 1
jaegzie Dizzy turned to far - hitting generator/tach gear Spridgets 12
B Dizzy Replacement - Petronix Austin Healey 6
Jim_Gruber Removing Dizzy - issues Spridgets 4
T Got my dizzy recurved by Jeff Schlemmer..... Triumph 4
J Dizzy vacuum line, manifold drain lines routing? Austin Healey 7
19_again GT6 Lucas Distributor cap on Delco D204 Dizzy GT6+ Triumph 6
angelfj1 New Improved Dizzy Rotors Triumph 3
tinman58 My dizzy Triumph 15
tahoe healey Dizzy Austin Healey 20
jlaird Question-Dizzy Spridgets 1
WALTER Vacuum source for dizzy Spridgets 4
G Brosky, ya got a picture of dizzy drive gear set.. Triumph 10
R 123 New Dizzy [Ignition System] Austin Healey 2
poolboy Lucas Dizzy with micro timing adjustment question Triumph 20
eejay56 84 Ford ranger Dizzy clamp bolt Other Cars 7
Z MK IV 1948-1952? 1.5L Dizzy Jaguar 0
texas_bugeye Dizzy vac question [NEW DISCOVERY] Spridgets 2
prb51 TR2/3/3A Tr3 Dizzy's Triumph 2
specialsports Mallory Dizzy Other British Cars 10
Bret I'm getting Dizzy MG 7
NutmegCT TR2/3/3A Dizzy dizzy - TR3A - Lucas 25D Triumph 18
8 DIZZY WIRE Triumph 9
Atrus 1/8” Capillary Tubing [Dizzy Advance] Spridgets 8
Atrus Dizzy – Mechanical Advance Weights Spridgets 19
G NEED A QUICK ANSWER...setting drive dog for dizzy Triumph 8
T Dizzy lost thread Triumph 24
guzzul I have a wobbly dizzy.... Triumph 6
Woodie hs2 & vac to dizzy - urgent - car apart in drivewy Spridgets 11
S Dizzy cap, HT leads Austin Healey 14
jlaird Dizzy set up Spridgets 4
R Dizzy Quiz Triumph 4
S Dizzy options Triumph 5
