jaegzie
after timing the BE and getting it running(1275), I wanted to hook up the tach, mechanical with the original tach, the diaphragm thing on the top of the disty where the vacuum line connects is turned too far over and is hitting the gear on the back of the generator.
I have two different style of disty caps, both position disty in the same position. What I mean is one cap faces the wires 90 degrees in comparion to the diaphragm and one lines them up with the diagraphm. I should be able by changing the where the wires are in the caps change the angle the disty sits correct.
Currently looking at the cap it is 43c12 with 4 and 2 being the higher ones. If i change the pattern to 31c24 would that enable the disty to be turned back 90 degrees? Can I even do this or is there something else I can do to get the disty turned ot of the way.
TIA,
Mike
TIA,
Mike
