in need of help. tuned car, timing, valves, compression good, fuel mix good, idles great but when i throttle up it sounds like its sucking air and stalls. so i decided to check float levels, they were low so i adjusted as per manual, 39mm with 11mm of range. but while i had them off noticed one cover had a brass orifice pressed in on the secondary side and the other did not. don't know what to call it, it didn't show in the manual. any thoughts?
