Has anyone out there had any experience making/machining a custom transmission input shaft pilot bushing?
If so, what material did you use?
From what info I can find, the typical pilot bushing is cast sintered bronze, not regular bronze and is not a machined piece. Normal machining apparently can cause problems with the oil in the bushing not getting to the input shaft surface.
