BW66 Tranny Weight for 4.2?
bmurphy7369
Hello Group,
Can anyone tell me the shipping weight of a Borg-Warner T(ransmission)66 from 1986 XJ6? Or share your shipping experience? Whom is the best carrier to use and the most cost effective? Any help would be greatly appreciated. Thank you for your time.
Brian
John S Farrington
Re: BW66 Tranny Weight for 4.2?
Bryan, The last time I shipped a series 3 transmission, I had to use a trucking line due to its weight being over 75 pounds. One convenient way is to use a plastic or tin garbage can with stuffing around the transmission. Then tape up all seams. Shippers do not like oil dripping packages. Building a crate can be EXPENSIVE. Some shippers will accept the transmission banded to a pallet; ask your local carriers.
bmurphy7369
bmurphy7369
John,
Thanks for the tips. Sounds like the way I'll go with it. Much appreciated.
Brian
M Tranny Mount Bolts Spridgets 3
M Tranny Mount Spridgets 1
R Wanted rib cage tranny part Spridgets Classified 0
R 59 Bugeye rib cage tranny hard shift into reverse Spridgets 0
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
R Tranny ? Spridgets 3
2 TR2/3/3A Oil leak in tranny Triumph 4
J TR5/TR250 tranny woes Triumph 15
Got_All_4 TR4/4A Interesting Tranny problem Triumph 9
Jim_Gruber 210 Tranny Shop Manual Spridgets 2
Got_All_4 General TR This Happened Twice [TR6 tranny in a TR3] Triumph 17
F Ribbed case tranny in 948 bugeye Spridgets 2
M Wanted 5 speed tranny for my 1275 bug eye Spridgets Classified 0
M Wanted dATSUN 5 SPEED TRANNY Austin Healey Classifieds 2
Jim_Gruber 210 Tranny Case Mods started this evening Spridgets 15
Got_All_4 TR2/3/3A Something is really wrong? Overdrive Tranny Triumph 7
histerical Datsun tranny help please Spridgets 18
histerical Tranny build Spridgets 0
M TR2/3/3A Engine/tranny angle with the ground? Triumph 7
GTP1960 TR2/3/3A tr6 Type A OD tranny service Triumph 10
C stupid question on tranny oil Spridgets 9
Got_All_4 General Tech How do i get these out? Tranny cover plugs Triumph 6
BillyB62 Sideshift OD tranny Austin Healey 15
Griz Tranny O/D Austin Healey 2
Got_All_4 TR2/3/3A Steering box oil seal & same seal for input shaft in tranny Triumph 2
Got_All_4 General TR Tranny Fork alinement problems & TR3 shifter in a TR6 tranny Triumph 17
Got_All_4 General TR Identifing the tranny number on my j type Triumph 7
C TR2/3/3A Need Help Identifing Tranny with Overdrive Triumph 4
Rut 210 tranny Spridgets 10
T TR4/4A Want to buy tr4 tranny for my tr3a Triumph 17
R Od/tranny 100-4 Austin Healey 6
D Spitfire '65 Spitfire MKII tranny pblm Triumph 1
Tinkerman TR2/3/3A Continuity Check on Tranny Lock out switches Triumph 2
Tinkerman TR2/3/3A Tranny lock out switches Triumph 9
Got_All_4 TR2/3/3A J type on a TR3 tranny Triumph 3
Tinkerman TR2/3/3A Hole on top of my tranny tunnel Triumph 9
Tinkerman TR2/3/3A 1960 TR3A Holes in the tranny tunnel Triumph 11
T TR4/4A Heat shield for tranny cover Triumph 4
pkmh BJ8 Tranny Issue - Slightly hitting gears when shifting Austin Healey 13
Boggsy64 MGB What is the purpose of the center assembly at tranny mount? MG 2
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
RJS General TR Valvoline VR-1 20W-50 or Straight SAE 50 for OD Tranny? Triumph 16
Lukens TR2/3/3A TR3 A tranny questions. Triumph 8
J TR4/4A Can't get the TR4 tranny and OD to mate up Triumph 12
CJD TR4/4A TR4 or TR3 Tranny? Triumph 5
L Overdrive and tranny oil Austin Healey 19
J BN2 Tranny Jumping Out of 1st Gear Austin Healey 1
C Tranny dip stick question Austin Healey 11
R TR2/3/3A Will this Tranny fit my TR3 ?? Triumph 9
