I recently had my '67 freshly painted. It came out beautifully but chose that very moment to develop a brake boost problem. The brakes kept locking up after I had new calipers and brake lines installed. The brake & muffler shop right next to the body shop was sure they could take care of it. Got them the rebuild kit and new leather ring and they tried to rebuild it, unsuccessfully. I now have the vacuum boost unit at home as I try to figure what to do. It has the recently installed rebuild components and new leather ring. It appears the "brake" shop just installed the leather ring on the vacuum piston, rubbed some white grease on the ring and forced the piston into the cylinder. Didn't work for long.
I now have the unit at home with the main body disassembled and have cleaned the cylinder and it looks OK. I'm going to re-coat the cylinder with Sandstrom lubricant. It appears to be in good condition but it is 47 years old so I'm figuring that while it's out is the time to do it no matter how it looks. I'm now starting to shape the piston and ring to fit the cylinder by hand sanding the leather ring to fit the cylinder.
My immediate questions;
How far into the cylinder, while working against the spring, should the piston travel for the boost unit to operate correctly - 1/2 way? 3/4 travel?
Anyone have a better method or tool for shaping the leather ring? I'm hand sanding starting with 60 sandpaper and moving to 150 and 180 to finish the surface.
I've read as many previous threads I could find on BCF and at this point I think this most recent jammed piston problem was just an improperly installed ring from this "repair". But I think something else brought the problem on originally. I've read of people disconnecting the boost and using only the basic manual brake system in the car. How is the unit to be disconnected and still allow relatively normal braking? Just disconnect and cap the vacuum line? Leave the brake fluid lines connected and in place? How do the brakes feel without boost and does it have a big impact on stop distance? It seemed that previous input on this subject was split pretty widely. Would love to hear what others have experienced.
Thanks
Thanks
