Legal Bill
All questions relate to a '65 BJ8. The first four questions concern the tranny tunnel carpet.
1. Is there supposed to be a jute pad under the tranny tunnel carpet?
2. Is there supposed to be an access flap in the tranny tunnel carpet to access the oil fill and dip stick for the tranny.
3. Are there supposed to be carpet snaps on the steel section of the tunnel (over the drive-shaft)? If so, how many on the steel portion?
4. How does the tranny tunnel carpet treminate at the firewall and footwells? Is it supposed to overlap the carpet that is glued to the firewall and inside wall of the footboxes, or is supposed to form a close seam with the forewall and footbox carpet?
5. Does the piece of carpet that just lays on top of the rear bulkhead go over or under the drain hoses attached to the gutter for the convertible top? It seems to fit better underneath, but in Moment book there is one picture of the carpet and it shows it laying over the center drain hose. It does not really show how it is configured on the ends. Maybe it goes over the middle hose and under the two end hoses?
6. Is there a tool for installing the carpet clips into the carpet? something that will make the three holes for the carpet clip?
As always, thanks for your time and wisdom.
Best,
Bill
Best,
Bill
