before I put this in my differential
jackag91
Is there any problem with using this?
Royal purple gear oil product sheet
vettedog72
I think all the Royal Purple products are great because they lubricate better than oil of yester year BUT the composition of seals, gaskets and retainers as well as the design of these devises made in the "old days" are not the same as the new high tech products of today. I don't think our old cars can take advantage of todays improved products with out modifications. It's not just Royal Purple but synthetic oils in general that seem to leak more than the non synthetic oils. If you don't mind a little more oil leaks, go for it; you may be one of the few lucky ones that has no problems.
TR3driver
Great Pumpkin - R.I.P
Should be fine, IMO. I use Valvoline full synthetic gear oil in all my Triumph differentials, and it doesn't leak any worse than dinosaur juice for me. I also credit it with making my TR3A diff hold up so long (over 100,000 miles since I bought the car & well-worn then).
J
jackag91
TR6BILL said:
I agree with Vettedog. Stick with Hypoy 90.
All of the castrol products I saw in the stores are all GL-5. This was the only one that I could find that was GL-4.
I think I am going to give it a try. I will let you know if I have any issues.
YankeeTR
I used synthetic in the rear gear of TS 74011 L without any problems. BTW...That IS a GL-5 lube but it should be fine for use in the rear axle.
J
jackag91
True that is a GL-5 lube, but it does have this note on it.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]
My vehicle's transmission specifies an API GL-4 gear oil. Can I use Max-Gear?
Yes. Max-Gear possesses both API GL-5 and GL-4 certification. Max-Gear is formulated with Royal Purple's proprietary, Synslide additive technology to provide the exceptional film strength necessary for GL-5 applications, yet it is noncorrosive to soft metals found in manual transmissions that specify a GL-4 rated lubricant.[/QUOTE]
Bugeye58
I used nothing but Royal Purple in the tranny and the diff on the Spit racecar, and never had a leak or a problem. Good stuff, in my estimation.
Jeff
jlaird Before I put in classifieds Spridgets 36
bugedd Before I put it on ebay.... Spridgets 0
middie Before I put engine back Spridgets 22
B Before I put the heater in my 57... Triumph 10
Hap Waldrop Caution: Put your shades on before viewing :] Spridgets 10
tr7andtvr 280i For Sale [before I put it on ebay] $6500.00 TVR 1
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
DrEntropy Before they were Vintage Racing 0
JPSmit Ford Taunus - never seen on in the flash before Spotted 4
B Before and After Pics Longbridge 100-6 Austin Healey 5
D General TR Fuel filter before the pump. Triumph 2
JPSmit Hagerty Prediction - Cars to buy now [before they get expensive] Spridgets 1
S BJ-8 SU Fuel Pump Clicks Much Faster Than Before Austin Healey 9
TomMull Why didn't somebody tell me about this before Restoration & Tools 5
P T-Series MGTD - before and after MG 3
D TR2/3/3A Excessive cranking before it starts. Triumph 47
D Prepping Floors Before Installing Interior Restoration & Tools 6
Csarneson Anybody seen this Front Shock Conversion Kit before? Austin Healey 6
J Wedge TR8 research before purchase Triumph 16
H Machined Engine Block - Cleaning before assembly and paint. Not sure what to do? Spridgets 5
simon1966 Before and After Austin Healey 2
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
C Static timing before engine start up Spridgets 4
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
E Wanted Wanted: TR6 cylinder head- '72 or before Triumph Classifieds 4
Popeye Engine starving for fuel before tank is empty - 2001 Audi TT Other Cars 5
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
T TR2/3/3A Before and after lever shock absorber pictures Triumph 12
R Last minute check before engine install Austin Healey 26
T TR4/4A How to determine if the crank is good before pulling the engine out Triumph 8
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
PeterK TR4/4A Never seen a dual exhaust cobbed this bad before. Triumph 2
RickB Questions before seeing insurance appraiser Spridgets 12
TRMark TR4/4A Leaking Drain Tap before I could even get the radiator full Triumph 1
B Spitfire before i swap this od transmission into my mk3 what would you do? Triumph 11
DNK Never Seen One of These Before Other British Cars 3
hilsideser Never seen one of these before... Spotted 5
Lukens TR2/3/3A Before I remove my steering box... Triumph 10
apbos What can I bolt to the engine before I install it? Spridgets 12
DerekJ Ever seen wire wheels like this before? Austin Healey 5
Lukens TR2/3/3A Think I'll add a fan on TR3 before I need it. Am I being overly cautious? Triumph 13
L Adjusting the bows before top installation Austin Healey 2
P Thanks Basil!! Spridgets before Sunbeam! Spridgets 1
F Somebody buy this owner's manual before I do Austin Healey 28
RickB Before and after top with 303 Aerospace protector Spridgets 8
bugedd Last chance before it becomes a planter Spridgets 11
JPSmit Before and Afters Restoration & Tools 4
mrv8q The Night before Christmas Triumph 2
regularman Before I would pay $2900 for this bonnet Spridgets 6
