An argument against tube shocks...
Morris
They ride and handle great when first installed, but golly do they wear out in a hurry. I have a lifetime replacement guarantee on them, but I am definitely filling up the landfill with dead tube shocks.
Boink
Bronze
What's all this fuss about tube socks. - Gilda
Branson
why do you suppose they are wearing out so quickly on you? I would think they should be good for atleast 40 - 50k mi? Maybe its time for some of them fancy chromed carrera shocks.
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
GTP1960 Crimes against nature......& otherobnoxious paint jobs Other Cars 1
2 TR2/3/3A Fitting mirror against new windscreen Triumph 5
RickB GBP falling pretty quickly against USD Spridgets 9
AUSMHLY Cup holder in a Healey..against the grain Austin Healey 34
Sherlock Travesty against a Mini? Or good artwork? Other British Cars 6
S ram pipes against K&N's help needed - newby Triumph 3
L Axel wont seat against Hub Austin Healey 5
tinman58 TR2/3/3A Vent tube Triumph 3
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
D Capillary Oil Tube Fastener Austin Healey 5
P MGB Tube axle wear MG 3
M Capillary Tube repair Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
G Stator Tube Nut and Olive Austin Healey 9
Cutrog1 BJ8 Fuel Tube Installation Austin Healey 10
P Classic Tube Pre-Bent Brake Lines Austin Healey 5
71TR6 TR2/3/3A TR3A Breather Tube Attachment Triumph 6
C TR2/3/3A stator tube Triumph 6
B TR2/3/3A Control Head/Stator tube orientation Triumph 8
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Jim_Gruber Pages from Porter Spridget Restoration Manual on Seat Recovering, You Tube Videos Spridgets 4
D TR2/3/3A stator tube will not go down Triumph 0
AUSMHLY Tube vs Tubeless discussion :] Austin Healey 28
F TR2/3/3A Tie member[front apron support tube] Triumph 11
S Wanted stator tube Austin Healey Classifieds 0
S stator tube nut Austin Healey 7
D Best little tube bender Restoration & Tools 8
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
K TR2/3/3A The rear axle "tube" seal replacement. Triumph 6
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
K For Sale Curved tube intake manifold...2" Triumph Classifieds 2
M Questions about stator tube and trafficator fixation Austin Healey 31
X BE jacking tube access holes and top bows. Spridgets 1
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
D BT7 stator tube Austin Healey 39
J TR6 TR6 Cross Tube Differences? Triumph 6
R Capillary tube temp gauge Austin Healey 7
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
K TR4/4A Pushrod tube leaks? Triumph 2
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
D TR2/3/3A Vacuum advance tube Triumph 6
T Wanted tube shock set-up/brackets for MGB MG Classifieds 1
