Hi James,
For some reason they stated to me that the problem was with the bonding between the alloy shell to the steel lining.
Now, I know that the TR4 drums are being re-produced, and have fitted them to several TVR's, encluding one SCCA race car with-out any problems.
As for used drums, they are very difficult to find. The good bit is that if you do find a used set, they are usually in good order and where removed to fit disc brakes and had little use.
I do have a set of early 100/4 Healey...the drum with 4-5 radial fins.
Regards, David. /ubbthreads/images/graemlins/thirsty.gif
