Advice needed - is it possible to... tach & choke?
RickB
Ok - Frank has the Nissan power train & the Lucas electrical.
I'm stuck with this Hitachi carb until I find a way to replace it.
The carb has an electric choke that doesn't work well, I'd like to replace it with a manual choke. I can get a choke cable easily enough, but how do I hook it up? I know this isn't specifically a Midget question, but it's in my Midget and I want to get it working better while I search for the right replacement.
Next, I have a good tach in the dash but it's apparently not connected. How should it connect? There's some kind of electronic distributor and what appears to be a standard kind of coil in the car.
Thanks!
Morris
If it is just a temp fix, there is a manual choke conversion kit available in the "HELP!" section of most big parts retailers (Autozone, Advance, etc.). It should fit up with maybe a little modificaiton. It's a pretty flimsy set up though, and I would not expect it to be a good long-term solution.
I hate to be a negative Nelly, but my experience with those Hitachi carbs is that once you disrupt the very complicated vaccuum circuitry, it is nearly impossible to get them to run right.
RickB
RickB
Re: Advice needed - is it possible to... tach & ch
Thanks Morris, it runs like crap when cold & pretty good when warmed up. Thus I was thinking of just ripping off all the choke related stuff & putting on a manual choke.
tosoutherncars
Everyone who runs the craptacular Zenith 150CD / water carb is feeling your pain, Rick. I certainly understand the appeal of the idea of a mechanical choke. I had to change to a Weber to get one...
-Duncan
RickB
RickB
-Duncan
Yeah - maybe that's what I will have to do if I can't find a manifold & twin SU setup at a price I can afford.
R Possible Midget purchase - advice needed Spridgets 11
N Electrical Troubleshooting Advice Needed Spridgets 6
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
F Water pump replacement on my BT7 advice needed please Austin Healey 18
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
R Remove engine/transmission advice needed Austin Healey 4
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
L Advice Needed Austin Healey 30
L Advice Needed Spridgets 20
M Some Tech Advice Needed for Horn Brush on 59 Bugeye Spridgets 10
Jim_Gruber Coolant Bypass Nipple on 948 Welded Closed - Advice needed Spridgets 7
A 100/4 Fuel pressure advice needed Austin Healey 1
R Bugeye rear wheel advice needed Spridgets 20
B Another Restoration Thread - Advice Welcome [and Needed] Austin Healey 25
JPSmit Truck diagnostic advice needed [I suspect it is dead!]] Other Cars 7
PatGalvin TR2/3/3A Leaking SUs. Advice badly needed Triumph 15
dklawson Spitfire My Spitfire Mistake - Advice Needed Re. Head Gaskets Triumph 14
D Car Buying Advice Needed Please :] Other Cars 2
DerekJ Paint removal - advice needed Austin Healey 13
PatGalvin TR2/3/3A Accelerator Pedal Advice Needed Triumph 21
JPSmit Engine Analyzers advice needed Restoration & Tools 8
O Battery box install- advice needed! Spridgets 4
1 More advice/knowledge needed MG 4
R Expert advice needed Spridgets 10
T T-Series TF Parking Brake Disassembly Advice Needed MG 2
A master cylinder advice needed Triumph 7
M 1275 Exhaust Manifold Needed - Along with Advice Spridgets 5
M Door weatherstrip repair advice needed MG 4
Morris Emergency advice needed Spridgets 13
G Advice needed in removing front left fender. Triumph 2
JPSmit OT phone wire advice needed Restoration & Tools 5
healeynut Steering Wheel restoration - advice needed Other British Cars 0
healeynut Steering Wheel restoration - advice needed Restoration & Tools 7
T Rebuild/Restoration advice needed. Triumph 23
J painting over por15 - advice needed. Restoration & Tools 7
newmexTR3 emergency advice needed! Blown pushrod Triumph 17
T Wedge TR8 passenger floor - advice needed Triumph 7
B TR2/3/3A TR3 front bearing/hub advice needed Triumph 6
B TR2/3/3A Advice needed - cleaning TR3 brake pipe union Triumph 11
B Looking for a TVR - Some advice needed TVR 12
S Advice needed - 56 MkI 2.4 Jaguar 32
jjbunn Advice Needed: Batteries and Hole Plugging Triumph 29
Morris Oil pressure prob— advice needed Spridgets 7
R TR6 TR6 Steering wheel advice needed Triumph 6
Mg_Bizzle Considering 2nd hand engine, advice needed MG 26
T Crypty's front hubs-advice needed Triumph 58
fmichaels tub advice needed Spridgets 2
ahpook Boy, will my wife be mad. Advice needed... Spridgets 19
RobT Permanent Garage Advice Needed Triumph 58
RobT Temporary Garage Advice Needed Triumph 16
