Advice needed - is it possible to... tach & choke?
RickB
Ok - Frank has the Nissan power train & the Lucas electrical.
I'm stuck with this Hitachi carb until I find a way to replace it.
The carb has an electric choke that doesn't work well, I'd like to replace it with a manual choke. I can get a choke cable easily enough, but how do I hook it up? I know this isn't specifically a Midget question, but it's in my Midget and I want to get it working better while I search for the right replacement.
Next, I have a good tach in the dash but it's apparently not connected. How should it connect? There's some kind of electronic distributor and what appears to be a standard kind of coil in the car.
Thanks!
If it is just a temp fix, there is a manual choke conversion kit available in the "HELP!" section of most big parts retailers (Autozone, Advance, etc.). It should fit up with maybe a little modificaiton. It's a pretty flimsy set up though, and I would not expect it to be a good long-term solution.
I hate to be a negative Nelly, but my experience with those Hitachi carbs is that once you disrupt the very complicated vaccuum circuitry, it is nearly impossible to get them to run right.
Re: Advice needed - is it possible to... tach & ch
Thanks Morris, it runs like crap when cold & pretty good when warmed up. Thus I was thinking of just ripping off all the choke related stuff & putting on a manual choke.
Everyone who runs the craptacular Zenith 150CD / water carb is feeling your pain, Rick. I certainly understand the appeal of the idea of a mechanical choke. I had to change to a Weber to get one...
-Duncan
-Duncan
Yeah - maybe that's what I will have to do if I can't find a manifold & twin SU setup at a price I can afford.
