Emergency advice needed
Morris
I just discovered that me rear left brake is dragging. Should I ease her home, or get a tow?
Answer needed before I finish my margarita!
RickB
Assuming drum, can you release it a bit by backing off the adjuster? Is the E-brake cable nice and loose?
Deleted member 8987
If the e-brake cable is rusty, and hung up a bit, moving the housing around a bunch will often release the tension.
Also, try backing up and hitting the foot brake.
Shoe movement will sometimes kick a sticking e-brake off.
I had a car that was like that once.
At the time, finding a one-piece rear e-brake cable for a 2WD 1949 Willys Wagon was not an option.
G
That's cause you didn't know Raymond Cusimano !!!!! ( or he was dead already.)
Morris, beating on the back plate w/ a hammer works too fer hung up e brakes and such.
Deleted member 8987
This was 30+ years ago.
4WD parts all over, but not 2WD.
Finally put a Mustang 8" in the back with the cables it came with and other than some cable slack adjusters, works fine.
Morris
Morris
Ebrake is perfect. I think it's a busted return spring.
I don't think I can get to the adjuster in the busy restaurant parking lot.
Tow it?
G
Is was good and alive then and had ANYTHING hard to find IN STOCK. Probably had a few new and used. He had several whole wagons around and a really nice fully restored Jeepster for his wife. He was a great guy, you would have liked him. He passed away in '88.
He once ran a guy off for asking him if he had points and plugs for a Blazer.
"Get the hlll out of here!!! Go to NAPA !!!! We only have hard to find stuff !!!!"
He was quite a charater.
RickB
Tow it?
Sounds like it, if you think it's doing damage to drive it.
Plus - Margharita's? Yeah - tow it. :wink:
Deleted member 8987
Unless you want to jack it up, pull the wheel and drum right there in the parking lot, then hike to someplace that might have a spring, if you're concerned, tow it.
Deleted member 8987
Oh, and since you won't be driving, have another couple of Margaritas while waiting for the truck.
regularman
I would have one more and then drive that sucker :wink:
yeah is sounds like a stuck E-brake. Let it cool good and it might free up. Me, I would pull it there in the parking lot. You still got to fix it there or at home. Still, I am not normal, so do what you think best
JPSmit
should a towed it :cryin:
newmexTR3 emergency advice needed! Blown pushrod Triumph 17
M Need Some Advice on a BE Emergency Brake Spridgets 13
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
R General TR Emergency hot wire - because you never know whats next Triumph 2
R TR2/3/3A Emergency Brake Adjustment Triumph 29
I Wanted emergency brake rods from later Spridget Spridgets Classified 0
maxwedge5281 adjustment of emergency brake Austin Healey 4
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
T TR2/3/3A Emergency Brake Handle Triumph 7
W Emergency rotor fix Austin Healey 2
bigjones Installing a spare distributor in an emergency Spridgets 52
G TR4/4A Emergency brake dust covers Triumph 4
RJS Emergency hood/bonnet release Triumph 22
B MGB Dumb emergency brake questions...help requested! MG 5
J TR2/3/3A Dissassemble TR 3A emergency brake handle. Triumph 4
G Emergency...Sorry MG 19
Trevor Jessie Emergency Stop Spridgets 8
J Emergency brake lever needed Spridgets 2
jvandyke emergency help needed in Linden, NJ Spridgets 21
H Triumph Emergency Kit Triumph 18
H Spring for emergency brake MG 0
lreyburn Road Trip Emergency Kit Austin Healey 18
D Spitfire Spitfire emergency brake assembly - need photos Triumph 3
S Emergency Brake cable FORUM Navigation Questions 0
S Emergency brake stuck MG 12
S Emergency Brake cable MG 6
JPSmit emergency brake light switch Spridgets 6
JPSmit Quick question #2 Emergency Brake Spridgets 1
A Emergency Brake Handle Correct Reassembly Order ? Austin Healey 2
RickB FIXED - Distributor removal 'emergency' [not] MG 39
D emergency brake cable Spridgets 2
L Emergency Question: Time sensitive Spridgets 4
healeyboz emergency brakes Spridgets 6
Woodie Urgent help...emergency flasher wiring Spridgets 7
T TR6 tr6 topseal emergency! Triumph 8
regularman The spridget long trip emergency tool kit Spridgets 21
ScottTR6 Emergency bonnet release Triumph 12
Woodie emergency flasher switch Spridgets 7
M Spitfire Removing the emergency brake grip;1979 Spitfire Triumph 0
kodanja Emergency Brake Knob? Triumph 8
MadRiver Emergency Bonnet Release Install Q's. Triumph 10
I TR6 Emergency parts for TR6 road trip Triumph 6
TR4nut Poor Man's Emergency Bonnet Release - It works! Triumph 5
T Where do I attach a tow line for emergency tow ? Triumph 6
Brosky New "Emergency" Hood Release Kit arrived today Triumph 3
Sherlock 1957 Wolseley [in CA] - emergency rescue Other British Cars 5
