A-pillar repair Question
64rocksprite
OK folks..I searched and found lots of pictures of the A-pillar repair, discussions on aligning doors etc.
What I cannot find is any reference to how to get the skin off on the edge nearest the door. I see that is it spot welded to the other side by the fender, but the door side almost appears to be simply folded over (?)
Is it spot welded also? I just need to do the lower 6" patch..not the whole pillar. The tapping plate and its structure are gonzo..I have new of both.
What I have done so far was to cut horizontally about 1/2" below where the patch will go (but not all the way through on the 'back' or door edge), drilled out the spot welds and then cut vertically down the skin about 1/2 way to remove the front 1/2 of the rusted out skin..
How to get the back half off? I'll try to post some pics of where I am later tonight..
THanks!
jlaird
It is just folded over to the best of my knowledge.
ChrisS
The trailing edge is just folded over. As you said, cut the outside with a cutoff wheel being careful not to cut the panel behind it. Then take a hacksaw blade and cut the edge that is folded over. They sell holders for the blades that have the blade stick out but you can do it with a gloved hand. That's it, I did the job this past weekend. Good luck.
Jim_Gruber
When refolding that edge be careful as you'll find it to be very, very sharp. Don't ask how I know, it still hurts thinking about it. A widemetal bending type pliers helps to bend that edge over but can also be done with an adjustable monkey wrench. Just bend slowly and evenly across the width of the folded over tab.
64rocksprite
64rocksprite
Thanks all,
I just stopped as I was afraid to start tugging on that folded piece..I didn't want to tweak the metal above it.
Chris - when you say to cut the edge..does that mean using the blade on the inside parallel with the outer skin? I'm guessing it is with the suggestion of the hacksaw blade holder!
Bill - thanks for the link..I had found that page..but still was not sure how the piece was attached at the back edge (until now!)
It looks like they drilled the front spot welds first and just unfolded the back?!
I like Chris' method..less likely to bend something I don't want bent!
chrpark
I looked at that eclectic site- good clear pictures- but I wondered, why leave the hinge and screws in place? It looks like a fair amount of surface rust inside the pillar they coated with something (POR?) . I cant imagine those hinge screws would EVER come out with the rust and POR in there
Jim_Gruber
Soak and soak those hinge screws with PB Blaster and they will come out. I believe those are POSI Drive Screws not Phillips Head. Heat them as well before trying to unscrew. Could not find proper POSI Drive Screws locally and ended up using rather thin hex bolts of proper thread. Doors close just fine and alignment is correct now.
64rocksprite
64rocksprite
Jim,
Amazingly..like every other nut/bolt on this car (so far) I gave the hinge screws one squirt of PB..set overnight and the screws for the door came right out, which once I cut into the skin and saw what was left of the tapping plate...is amazing. The threaded plate itself was there..and that was it, the rest had turned into rust flakes laying on the top of the rocker.
I used a phillips head for the hinge screws. I still don't get the difference of POSI vs phillips..I guess I will once I strip one out!
These sure as heck looked like a phillips head..and a blunt-nose large phillips screwdriver gave a good bite on them. (or is a "blunt-nose phillips" actually a "POSI"??)
I too was surprised that eclectic left all that cancer, albeit coated, in place..what a nice fit of their patch though..didn't even look like it needed any filler at all!!
Philips heads are designed to slip once a certain amount of torque is reached. "Posi" drive are designed to grip and not slip. "Posi" has little grooves in the corner that are parallel to the axis of the fastener.
64rocksprite
64rocksprite
Thanks Trevor..first time I've seen that explained! I assume the bit/driver is specific then..
Yup... sometimes you can buy a set of "security bits" that include "posi" drives.
Otherwise, it is generally a special order item.
Jim_Gruber
Glad you were able to get things apart. Final alignment is a little tricky but just keep at it.
weewillie
what I use to remove screws that are rusted in is an impact driver (very handy tool)
64rocksprite
64rocksprite
Jim,
I have your how-to thread bookmarked on here..so I can find it again when the time comes..thanks for sharing that one.
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
CLEAH BJ8 Hinge Pillar repair Austin Healey 2
B Windscreen Pillar/Quarter Light Relationship Austin Healey 2
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
H Windshield Post to Body - Captive nut needs to be replaced - Pillar to Body Spridgets 2
R For Sale MK1 hardtop B pillar clips, reproduction part Spridgets Classified 4
HealeyRick Grey Windshield Pillar Seal Austin Healey 19
MisterB Shut pillar differences? BN4 to BJ8 Austin Healey 7
B BJ7 windshield pillar Austin Healey 1
B aluninun shut face pillar cover on BJ8 Austin Healey 8
pbraun Door pillar number used as VIN on title. What to do? Spridgets 11
BoyRacer Hinge pillar issue with BT7 Austin Healey 9
AH100M BN2 Door Shut Pillar Trim Austin Healey 2
M Need advice on fitting rear pillar interior trim.... British Motor Corp 2
wangdango BJ8 door hinge pillar plate redo Austin Healey 7
This14u Spitfire Pic of Spit A-Pillar Details Triumph 3
J Windshield pillar to windshield frame screw size? Spridgets 2
apbos Windshield Pillar Bolt & Nut Spridgets 18
B windshield pillar plating Austin Healey 2
N Aluminium facing on sills and shut pillar, BJ8 Austin Healey 7
M Shut Pillar installation - 62 BT7 Austin Healey 3
Geo Hahn TR6 TR6 A Pillar Seal Triumph 3
T A-pillar question Spridgets 9
T Anyone have pictures of the inner B pillar handy? Triumph 7
PAUL161 Windshield Pillar Grommets [Pillar to body]. MG 5
Jim_Gruber Door Fitting - A-Pillar Skin - Success Spridgets 5
GregW Measurement for shut pillar top piece BJ7 or BJ8 Austin Healey 6
R Top to windshield side pillar mount. Austin Healey 1
Jim_Gruber A pillar replacement Spridgets 24
B TR6 TR6 "B" Pillar seal installation Triumph 2
G Shut pillar placement bj8 Austin Healey 9
S Color of reservoir bracket to pillar Austin Healey 4
P BT7 door pillar cap installation Austin Healey 3
A Accurate - Door Pillar Finishing Welt Piping BJ8 Austin Healey 10
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
B TR6 Thrust face repair Triumph 1
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
C TR2/3/3A Frame repair and value Triumph 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
B Windscreen Motor Repair Restoration & Tools 6
O Jaguar rear window trim repair Jaguar 1
G Smith's temp gauge repair Restoration & Tools 4
O TR2/3/3A Good Repair Shop In New Hamphire Triumph 2
H TR4/4A Fender/Wing repair how to do Triumph 5
H TR4/4A Advise asked for front repair Triumph 1
Bayless How to repair broken vent window studs? Spridgets 1
AngliaGT MGB-GT Gauge Repair Recommendations? MG 4
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
D TR2/3/3A TR3 repair in Cincinnati Triumph 0
