Moss kit w/ new bottom foam & diaphragm. Tips for better installation. Due to time limitations, want to do driver bottom 1st, and follow up a month or two later with back. Moss instruction sheet shows seat back 1st. Question 1; Is this really necessary??? Don't see why, but will do back 1st if necessary.
Seat bottom removed. Seems like after install of new foam and cover that it would be good to put 1/4 inch plywood sheet over seat bottom and pull down/compress slightly (1/2-3/4 inch) with straps before gluing to rails and installing clippy-dippys. This should make bottom snug/tight. Don't see any suggestions to that regard in 'seat upholstery' search. Don't find any step-by-step on seat upholstery. I am not an upholstery guy, and don't want want to reinvent the wheel on this job. Upholstery people have lots of secrets that make them do the job better than the rest of us wrenches. Question 2; any help on seat upholstery stet-by-stem late model midget???
Driver seat back doesn't get a lot of abuse as compared to seat bottom. Did not buy back foam. Without removal, I now think back foam may be lumpy/marginal. Back foam is about $100, 2 1/2 times price of bottom. Question 3; Is back normally OK?? (105K miles) Happy to spend $100 if really makes a difference.
Passenger seat no cracks/tears and foam feels OK. Question 4, after 35 years are you supposed to just bite the bullet and spend the money, or is passenger seat bottom and back foam usually not necessary???
