I am having to run new purple/white wires that go from the door switches to the transmission tunnel courtesy light (Thanks, PO). I ran a line from the passenger side switch to the driver side. There is also a wire coming from the the tunnel courtesy light up to the driver side. The problem is that I don't understand how they all connect on the driver side. Does the wire from the passenger side switch connect directly into the driver side switch and then out again to the wire coming from the transmission tunnel light? I have a wiring diagram, but it doesn't seem to cover this area. I don't understand how these lights work, and any help is greatly appreciated.
Kevin
Kevin
