TR2/3/3A 4:1 Diff in a TR3?
trrdster2000
Karl , if you are going to use it for AutoX, then great, if you are going to drive it for pleasure, forget it. You will be running a very high RPM at normal highway speed and really high on the interstate. My roadster is a 455 and it restricts me from driving to car shows on the interstate in the summer, I'm just in the way unfortunately.
Wayne
TR3driver
Great Pumpkin - R.I.P
The change in acceleration isn't as much as you'd think anyway. Too much torque wasted accelerating the flywheel, and lower gears just mean more goes into the flywheel. Steve Hedke made some careful measurements with "Scrappy", the TR3 he built to run in the History Channel's Great Race, and reported that he actually got better acceleration with 3.45 gears! That was with a stock engine, flywheel, tires etc. though. Still, I'm planning to go the same way even with a warmed-over engine, alloy flywheel and low profile tires.
Going from 4.1 to 3.7 did make it harder to spin the rear wheels. Probably a Good Thing, as it is still possible around here to get a ticket for "unsafe start". :D
charleyf
I have a friend with an overdrive who swapped out his 4:1 for a 3.7 and really loved the difference. For myself, I changed out my 3.7 for 3.45 in my two TR4s. We drive together a lot and when he had the 4.1 gears he would go up the steeper hills a lot easier than me. But on the downhill side I would be on his tail in a matter of seconds.
To me for all around driving the higher the gears the better. These engines have so much power it is a real waste to put low rear end gears in them unless it is just for auto crossing. One example that I use is that when I take off from a stop light behind my friend, he is shifting into second gear before he gets to the pedestrian crossing on the far side of the intersection, I am still in first gear and right on his tail.
Charley:fat:
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
K TR2/3/3A Randall.....4:35 Diff in a TR3? Triumph 4
TRclassic3 TR2/3/3A diff free play tr3 Triumph 7
K TR2/3/3A TR3 OD Trans & Diff Fluids? Triumph 4
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
K TR2/3/3A TR3 Diff Ratio for Highway Driving ? Triumph 5
T TR2/3/3A TR3 diff color -inside Triumph 27
K TR2/3/3A Tr3: Change in Diff=Change in Speedo reading? Triumph 7
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
Darwin GT6 Diff Help Please Triumph 2
skystryd Trans and Diff Spridgets 7
M TR4/4A Diff comparisons Triumph 2
N TR6 Triumph Diff which model??? Triumph 1
pbraun Wanted 3.9 diff for sprite Spridgets Classified 5
steve00136 MGB Diff refurbish MG 6
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
M TR4/4A Diff Conversion Triumph 3
T Diff Ratio BJ7 Austin Healey 5
Zitch TR4/4A Diff Fluid - GL4 Triumph 7
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
K TR2/3/3A 3.45 Diff ratio? Triumph 7
B best diff British Motor Corp 5
wangdango '67 XKE rear diff? Jaguar 2
Jim_Gruber Bugsy IV decided to leaked out almost a quart of diff fluid Spridgets 6
B diff ratio British Motor Corp 3
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
Jim_Gruber Speedi Sleeve Install and New Diff Gasket Spridgets 5
69MGC MGC Diff Oil MG 1
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
drooartz Diff pinion nut Spridgets 10
K TR4/4A Stromberg..."coupler" that links vacuum outlet to diff vacuum line is N/A? Triumph 3
R TR2/3/3A Lockheed diff setup Triumph 6
Boink 3.9 diff and pinion seal Spridgets 2
Boink 5 speed vs. 3.9 diff - either or both? Spridgets 165
Michael Oritt 3.54 diff for sale Austin Healey 1
drooartz Diff pinion seal Spridgets 8
Rut Diff plug tool Spridgets 7
Geo Hahn General TR Diff Pinion Seal Triumph 5
Geo Hahn TR2/3/3A Paint Dab on Diff Cover Triumph 6
A TR4/4A Changing rear diff seals Triumph 15
K TR2/3/3A Lockheed Diff...why is it considered 'weak"... Triumph 3
Gordon_Dedrick TR2/3/3A Drippy Rear diff cover Triumph 6
JFS Wedge Diff Cover Gasket Adhesive Triumph 10
G Diff and trans oil Spridgets 8
C TR4/4A Diff gear wear Triumph 10
mgedit TR2/3/3A Lockheed Diff Oil Seal Replacement Triumph 10
steveg Limited Slip GM Healey Diff Austin Healey 4
DerekJ 11:39 Diff for sale. Austin Healey 0
