Hi everyone!
I just joined in your discussion forum. I have a major problem with the front brakes locking up on one wheel on either side. That is the reason why the previous owner got rid of her. The car is in mint condition having covered only 43,000km to date. It has been parked for the last four years or so. The brake system is TEVES with ABS. According to the last owner, the problems started when he fried the brakes coming down a very steep and long hill. When he got to the bottom, smoke was coming out from everywhere with a nasty smell of burnt brake linings. Since that time, the car always behave the same way. It brakes normally when the car is cold. After a 10km trip to the store and being parked there for 10 minutes, one wheel will lock up (either one) and pull the steering wheel off your hand, spinning you 180 degree on the road. Scary experience!
Front Brake Calipers, Brake Pads, Hoses, Tires have all been replaced. The system has been flushed, the fluid replaced with CASTROL LMA; The system was bled accordingly.
No change! No improvement!
After consulting with experts??, he was told that the Hydraulic Control Module, consisting of Brake Booster/Master Cylinder/Valve Body Assembly, had to be replaced. Does it sound right?
