I suffer from self criticism. I think it is the only way you improve.
When I make pizza my wife says "That is great" I am thinking the dough could have had a bit more salt or the crust is too thick or too thin. I still enjoy it though.
On the other Midget forum I got some welding guidance that I will try. My go to was lower the amps if it is burning through. The advice for plug welds was increase the amps so you get in and out quicker.
I will give it a try.
I am backing up some areas with a piece of copper to try to stop the welds blowing through.
I have removed the caved in plate between the frame members under the front of the engine and am replacing it with a new piece. I think the PO was jacking it up using that area as a jacking point or they went off road with the Midget.
I am using 16 gauge plate to replace the 18 gauge that was on there.
David
David
