TR2/3/3A Photo of front TR3 carb linkage
T
TR3-Stu
Does anyone have a photo of the TR3 front SU carb linkage. I did a search but could not find one. My throttle seems to work smoothly (putting it back together after a total rebuild), but the short connecting rod from the linkage bell crank has a strange angle to the front carb throttle connector. Doesn't bind, but I'm not sure I have it right.
Stu Boyd
TS 78330 L
NutmegCT
Stu - here's a good photo and discussion of that linkage. It's not exactly intuitive!
Tom M.
T
TR3-Stu
Tom M.
Tom, thanks for the photo. I do think I have the choke linkage correctly set up, but it's the throttle linkage (especially from the front bell crank to the front carb throttle link) that I'm a little confused about. I appreciate the support.
Thanks,
Stu Boyd
NutmegCT
DavidApp
Did you just get a new bell crank?
The legs are not the same length and the one I got from one of the parts houses was set up the wrong way around. I ended up making my own as the parts house in question was not interested in fixing the problem. "That is all we have ever sold" was the response.
The mounting bracket was wrong as well.
I have made a couple of extras.
David
sp53
The linkage rod sits at about a 60 degree angle and looks wrong. The short linkage rod looks like it is going to rub on the side of the carb and will if you do not push the clamp down and force the rod away from hitting the carb. Basically you need to push the short linkage down and away from rubbing and then tighten the brass clamp and that is correct and as good as it gets. I will try and get a pic today.
steve
T
TR3-Stu
steve
Thank you Steve. That makes me fell much better. I think I've got it adjusted correctly. Have attached a couple of pics.
Thanks again.
Stu
T
TR3-Stu
DavidView attachment 73554
David, I have the original bell crank, but if I didn't, I'd be asking you for shipping info for one of yours. You do excellent work. Thanks for the help - this forum is extremely valuable for old British car lovers.
Stu
DavidApp
Thank you.
My TR3A came with 2 bell crank linkage assemblies but both were worn out so I ordered a new one from one of the parts houses. It was a waste of money so I made my own. I did recycle the new one by reversing the boss but had to make the part that bolts to the manifold.
David
sp53
Hi Stu I hooked mine up different than you, but that is not to say yours is wrong. I have always done mine this way, but never compared mine to anyone’s. The way I did looks straight forward, but again carb linkage on a tr3 is non-logical sometimes. I would like to see others before I commit.
Steve
sp53
On second look I think we did it the same and my linkage arm is longer or I pushed mine down farther before I tighten the nut on the brass arm. My linkage was new from TRF and might not be correct where as yours looks stock.
Steve
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
J TR2/3/3A TR2 - earlyTR3 front brake hose length and photo? Triumph 1
Todd78d Choke Linkage Photo Austin Healey 0
PAUL161 Photo: What Model of Healey? Austin Healey 7
D TR2/3/3A Drive your Triumph day photo Triumph 6
andrea 100-Six Photo Album Links Austin Healey 1
andrea AH 100/6 1957 Longbridge Photo Albums Austin Healey 5
Gliderman8 Photo editing FORUM Navigation Questions 6
K For Sale Re: TR# Blanking Plate Photo Triumph Classifieds 0
trrdster2000 Spitfire Added a few pictures to my Photo Album of the Spit6. Triumph 0
A Spitfire British Invasion 2018 - Stowe Vermont - Large photo album Triumph 2
A Spitfire I've been lax on posting - Summer Events Photo Albums - Lots of Pics Triumph 2
A General TR The British Motorcar Festival Bristol RI - 2018 - Large Photo Album Triumph 8
A General TR Brits by The Sea Photo Album - Harkness State Park - Connecticut Triumph 6
A Spitfire BMCNE Tech Session - Photo Album - Triumph 0
A Spitfire British Legends Weekend - Cape Cod -photo album Triumph 2
A General TR British Car Day Toronto - photo album Triumph 1
A Spitfire British Invasion 2017 Photo Album Triumph 9
A General Tech Fathers Day Show Portsmouth Abby - Photo Album Triumph 1
A Spitfire British Motorcar Festival - Bristol Rhode Island - Photo Album Triumph 3
A Post-War Other 1949 Triumph 2000 - Concours Class Photo Album Triumph 2
M SU HS 1 Carbs - Photo or Diagram? Spridgets 4
tcherek Jensen V8 Car Badge photo - anyone? Other British Cars 0
trrdster2000 GT6 Finally got a photo of some of our work on the Spit 6 Triumph 2
bugedd Photo Session Spridgets 11
steveg Folding 2-seater tops - photo article Austin Healey 3
MadMarx Wedge IMSA TR8 - a recent photo Triumph 3
aeronca65t Neat old photo-Midget Spridgets 1
aeronca65t Big AH photo-NY Times Austin Healey 22
aeronca65t MGA I love this photo MG 1
D odd photo Jaguar 6
sd80mac7204 Spitfire Photo journey: Spitfire rebuild Triumph 6
T GT6 Need a photo Triumph 2
A TR-3A wooden center dash panel photo??? Triumph 3
stuntflyr An October Drive. a photo for those of you in the frozen NE... Austin Healey 16
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
V 100-6 photo needed. Austin Healey 2
Stewart Found an early photo of my car MG 10
A TR2/3/3A TR-3A post 60K inside trunk latch photo Triumph 4
A Fender bead photo rear fender Triumph 12
steveg Photo upload test Austin Healey 14
R TR6 Need Photo of DS Wiring Harness Route '71 TR6 Triumph 0
M need photo of engine comp. of BE Spridgets 12
J Carroll Shelby photo Spridgets 6
T photo - odd request Triumph 5
A TR2/3/3A TR-3A door trim [photo please] Triumph 6
J TR2/3/3A Fabricating TR3 trunk panel,looking for photo help Triumph 16
A TR2/3/3A 1960 TR-3 V8 automatic photo Triumph 17
Brooklands Vehicles from Grandpa's photo album Other Cars 4
T TR4/4A my bad- need tr4 shifter photo Triumph 12
