Glass fuses
wrenchranch
Maybe this is "old-hat" to many of you but thought I would pass it along. Recently I have been working on an electrical gremlin in my Series II. Of course it was intermittant so that compounded the problem. All the fuses in the fuse block showed continuity across them so I discarded a bad fuse as the culprit. Then I noticed that one particular fuse in the block would test OK so long as I probed the fuse itself and not the clips that hold it. I removed the fuse and by probing each end, it showed continuity. Further probing revealed by testing the metal ends on their sides did not always show continuity. A short time later I noted a slight looseness in one end then "bingo" it fell apart to reveal rust enclosed in the end, unnoticiable thur the glass. New fuse, problem solved.
That only took a couple of days.
Greg in Montana
jessebogan
Sometimes the solder that secures the actual fuse wire to the end caps will melt (More common on high amp fuses) causing similar problems. That can be frustrating to find, as the test probe inevitably masks the problem. Cheap trick to find Lucas fuses. When in a junkyard, check every series 2 or 3 XJ6. There are multiple fuse boxes, usually full of Lucas fuses.
LarryK
I've seen this fuse problem on Fords. Mercurys, Jags, Triumphs, RVs, trucks and boats. Not a rare occurance on older vehicles, especially ones left outside most of their life.
homebeforedark
When I check any fuse box, I take a bulb-type 12 volt test light and first check the hot prongs , then the fuse , then the other side of the fuse , then the opposite prongs. It's easy and quick and will eliminate a little frustration.
RCarr Windscreen Glass Options Austin Healey 2
W Glass Washer Bottle Lids Austin Healey 0
D TR2/3/3A Windshield glass doesn't fit Triumph 6
W Need advice on installing new side curtain glass Spridgets 1
ROARRR For Sale 1930-40's AUSTIN 10 SALOON! straight, good glass, no through rust, very complete Austin Healey Classifieds 0
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
71TR6 TR2/3/3A New Windscreen Glass quality Triumph 6
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
B Windshield glass, where to buy Restoration & Tools 4
C MGB 1966 MGB windshield glass MG 4
J For Sale TR6 hardtop glass Other British Classifieds 0
B MGA Windshield glass MG 11
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
S TR2/3/3A glass and ring into new bee hive sockets Triumph 15
R TR6 TR6 Door Glass Triumph 5
GeorgeC Hardtop glass removal Austin Healey 2
R Quarter light glass removal Austin Healey 6
R Windscreen Glass Austin Healey 6
steveg Raise a glass to...Leo Baekeland - inventor of Bakelite Austin Healey 10
S TR2/3/3A glass rattled on the gas gauge Triumph 3
P Help With Side Vent Glass Removal Austin Healey 7
HighAltitudeTR3 TR2/3/3A Fuel bubbling at glass filter bowl Triumph 4
bugedd Measurement of windscreen glass Spridgets 7
Patrick67BJ8 Poor Fitting New BJ8 Glass Austin Healey 9
H General Tech Door Glass outer seals installation Triumph 6
K TR4/4A Mechanical fuel pump glass bowl level? Triumph 1
NutmegCT T-Series windscreen glass? MG 8
bugedd Windscreen glass question Spridgets 0
M Bugeye Hardtop Glass Installation Spridgets 6
KVH TR4/4A Removing Glass Windshield Triumph 4
Rob Glasgow Windshield glass Austin Healey 5
M TR4/4A TR4 door glass spacer wires. Triumph 1
JPSmit Hypothetical Question - Hardtop glass availability Spridgets 5
M TR4/4A Replacing inner furrey window glass seals. Triumph 4
V General TR Need help with installing glass and new seal into my surrey top. Triumph 2
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
M TR4/4A Door glass bayley channel clearance measurement. Triumph 4
M TR4/4A Sequence for fitting door glass? Triumph 7
B GT6 Mk1 GT6 glass domed fuel pump Triumph 6
I General TR Source for glass mirrors Triumph 5
M TR4/4A Door glass assembly help please. Triumph 2
B Tar case glass mat batteries Austin Healey 8
S door glass inner seal Austin Healey 6
TR3TR6 TR6 Tr6 windshield glass removal Triumph 6
Got_All_4 TR2/3/3A Need a temp glass Triumph 11
S TR2/3/3A glass beading them Triumph 5
J Chrome Polish and glass scratch repair Restoration & Tools 10
Editor_Reid TripleX Glass Date Codes Austin Healey 15
