Starting Mega squirt main board assembly
G
I figure since I'll be hopping around on crutches with no place to go, now would be a good time to assemble my mega squirt unit. I built the stim maybe a year ago, but haven't tested it yet ( cause I don't have a MS unit to test it with).
I'm reading up tonight and starting tommorrow.
Morri/ Jack, did you buy assembled units or build 'em yourself? I really gonna need you guys to help me get this thing tuned.
Doc, I'm suprised you haven't done this yet (build and install a MS) as it seems like it would be right up your alley.
Morris
I bought mine assembled. Worth every penny.
Do you have the v3.0 board? If not, you
may consider getting it. It's a major improvement over the v2.2 board. Also, there is not much support for the v2.2. boards anymore.
G
v2.2 and it's about 6 years old. I've already got $$ tied up in this one and would hate to spend more.
Platinum
If I were trying to listen to Radio Moscow, mebbe. Once a Weber side-draught is tweaked properly there's no need for spending time 'n money on all them fool management 'lectronics. :smirk:
lesingepsycho
I built mine from the kit and I loved every minute of it. I've built some electronic kits in the past... just some fun little hobby games... but building a usable ECU is by far the coolest and most useful electronics kit I've ever built. It was fun and the fact that it works is totally rewarding. Of course, next time, "<span style="font-style: italic">beentheredonethat</span>" and buy the preassembled unit. :laugh:
Tuning was really pretty simple. My advice is just spend the $40 and get the registered version of TunerStudio with the "Analyze Live" function. Then you just go for a drive and the car essentially sets itself and you can always make little tweaks here and there.
Anyways, I'll be happy to add my $.02 when needed. :wink:
Good luck, <span style="font-style: italic"><span style="font-weight: bold">read and understand the instructions</span></span>, take your time, and be patient!
JACK
PS- I had to read and reread the build instructions about a hundred times before I understood how to solder all the components and jumpers to get the crank trigger, MS, and EDIS4 to talk to one another but in the end, it worked the very first time and I know how it all works.
G
That's my problem, I don't know nuthin' 'bout tweakin' them side drafts. I've read you can do it at home,; I've read you can't. I've read the bits get pricey. Truth be told, I'm tired of getting in and out of the car to make adjustments. Jet kits oughta come with door hinge bushings. Never been taught carb tuning. I can clean 'em out and make them run like they should. Something tells me you can't learn how to tweak a side sucker from a book. Nobody 'round here to learn from either. Seems all the smart folks moved to south Florida.
Besides, I'm after economy and from what I've read, I won't be able to get the numbers I'm after outta one(especially two) of them side suckers.
Jack, I just want to control fuel for now. Glad to see you built it from scratch. I'm DEFINATLY gonna need your help soon, Morris you too. Doc, it sure would be nice to have a "mega" experienced hand such as yourself on deck that knows both electronic and carb tweaking. :bow:
Guys, this is a HUGE undertaking for me. Last time I played with electricity I was five. I stuck the plactic chrome plated tweezers from the "Opporation" board game in the electrical outlet and I've never come close to it since. Not that it's the same voltage, but I've always shy'd away from any form of electricity or electronics.
G
Think I'm gonna chicken out and have it built. The guy I got the kit from said $100 to assemble it and I think it'll probably be $$$ well spent. I can't gat anything for it like this and if I screw this one up it'll be another $240 to get one. Seems like the best plan.
lesingepsycho
Yeah, if you haven't played with <span style="font-weight: bold"><span style="font-style: italic">"'lectronics"</span></span> since you were 5, this might not be one to learn on. :crazyeyes:
$100 definitely is a good deal. That guy certainly isn't gettin rich doing it at that price. It took me many hours to complete. Of course, once you've done one, the second and third would go faster and faster and so on.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Jet kits oughta come with door hinge bushings.[/QUOTE]
:lol: HAHAHA.
JACK
G
Morris and I have similar cars and climates.
Guys, correct me if I'm wrong; if I use Morris' base maps and tuner studio, the car will tune itself with little to no input from me, right?
They'll be subtle changes, as I'll have two injectors instead of one that will need to be addressed, but it seems like Morris' maps would be a really good start for me.
Morris
Actually... The dual SU set up you have is very different from mine and I doubt my maps will be much good to you. They may be better than starting from the generic map MegaTune generates... but not much.
Morris
Naw... it doesn't really work like that.
Your fuel map is a map of Volumetric Efficiency... meaning... the efficiency of how well air is moving into your engine at a given engine speed and MAP. Megasquirt automatically calculates how much fuel to squirt (under perfect conditions) based on your engine size and injector flow. The VE table modifies that calculation based on real world engine conditions. So your manifold, throttle bodies, head, valves and cam are what affect the values in your VE table.
As you and I have very different manifolds and throttle bodies, it is reasonable to expect that our VE tables will look very different.
But hey... it's worth a shot.
Also, a guy nearish to where I work is offering a Megasquirt on Craigslist for $200. I would be happy to go pick it up for you if the kit you have does not work out. Mebbe you can send me your JimStim, so I can give it a quick once over before I pay him. Sadly, I do not have a JimStim.
https://austin.craigslist.org/pts/1989337219.html
G
Thanks for the offer but I'm gonna have my kit assembled. Just had a "talk" earlier and it seem some car funds are required for house bills. I might have to put this on hold for a while. If I could just get the SU's to quit vapor locking, I'd stick with those especially since you're not getting any better milage w/ MS. Too bad I can't put the dual DCOE's on the car. I would REALLY LIke to do that.
bigjones
Bronze
What are you using as a spacer/insulator? Last I heard, you were getting one cut. Why don't you use those black, inch thick spacers, as on the 1275.
I've sent off for one for my single HS4 - I'm expecting great things from it. That carb gets stinking hot (just using the old 1/4" cork ZS gasket).
By some miracle, Ace Hardware has the longer studs.
Yeah, what are the benefits from MegaSquirt if the mpg doesn't improve? I can appreciate the "coolness" factor but do you somehow get better performance or were you looking at it to solve this pesky vapor lock issue?
Cheers!
G
A cut 1" spacer to .441.
MS should improve milage, but Morris is getting them same as mine. It should help vapor lock as well as provide better performance. I also like the idea that I don't have to fab dooor hinge bushings from extra carb jets.
bigjones
Bronze
How come you just didn't use 2 spacers? Do you have clearance issues or did you just have the one spacer on hand?
Got mine in the mail yesterday for the HS4 - it is huge - 1 and 1/8" thick - is this a spacer (to move the carb away from the exhaust manifold) or did MG intend it as a heat insulator ? Did I also read somewhere that it is also beneficial to increase the distance somewhat between where the fuel is mixed and the intake manifold - something about fuel/air turbulence.
Cheers!
G
I cut one spacer/insulator into two pieces that are .441. Yes I have clearance issues. Nex time I pull the motor I plan on removing the federal brace completly. (grinding out the welds, not cutting out the piece.) I'll probabaly never put it back in, but at least I'll have the option.
Spacers are good for all of the above and it is supposed to help top end too.
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
sundown TR6 Starting Triumph 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
mgedit TR2/3/3A 56 TR3 Starting Issue Triumph 9
M Starting from cold Austin Healey 2
R Very Difficult cold weather starting problems! Austin Healey 21
R TR4/4A Starting TR4A after 30 years Triumph 12
R winter hard starting BJ7 Austin Healey 16
P Jump starting a positive ground BJ8 Austin Healey 4
W starting motor Jaguar 0
D TR2/3/3A Starting my Bodywork journey. Triumph 166
P TR6 Quick starting Triumph 2
Joe Reed General Tech Starting a screw in a tight location... MG 9
P TR6 TR6 hard starting Triumph 24
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
stretchit2 Starting Issue Austin Healey 6
M TR6 Intermittant starting problems Triumph 4
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
S Hard starting on Webers from cold Austin Healey 12
T TR4/4A Weird starting issue with my TR-4 Triumph 15
