Brosky said:
Dale,
Did you put a connecting boss or bridge on your trunk light grounds or just wire to rear panel?
<span style="color: #990000">A combination of both. I installed a grounding block, driver's
side trunk rear, left corner. Some of the bulb fixtures had ground wire spades which
I wired into a bullet. The bulb fixtures with no ground spades
I soldered ground wires and terminared with a bullet.
I ran the passenger side rear lights into a 4-way connector with a lead
wire crossing the rear and terminating into the left side grounding block.
Then I did the same for the left lights plus added the fuel tank ground to
the grounding block. I tied in the license plate bulb with a direct wire
to the grounding block. I think I have a total of 5 or 6 grounding blocks
in whole car re-wire.
It is amazing how useful and versatile the bullets and connectors are.
My socket holes were so beat up I could not get a functioning ground.
I actually wired the car twice. Once without grounding blocks and almost
nothing functioned. The 2nd time with blocks and everything functioned.
Hope this helps.
best regards,
dale</span>
