Hot Rod Rolls
William
That's not bad! /ubbthreads/images/graemlins/cool.gif But then again, it's just the sort of thing I'd do to a Rolls.... /ubbthreads/images/graemlins/devilgrin.gif
Matthew E. Herd
Not I, I think I'd make it the fastest car around! Forget the look, no one would be able to tell from the outside! /ubbthreads/images/graemlins/smile.gif
waltesefalcon
Thats pretty interesting. It is the most outrageous RR I have ever seen but it is at least respectfull of the marque.
Bruce Bowker
I'm leaning towards /ubbthreads/images/graemlins/nonono.gif
aeronca65t
This is the one I like. I think Jay Leno now ownes it (or he built a copy of this idea).
waltesefalcon
Nial, I have to agree with you nothing quite as awe inspiring as the merlin.
Matthew E. Herd
Hehehe ... 1500 hp in a sedan ... that's what I'm talking about! /ubbthreads/images/graemlins/devilgrin.gif
sammyb
I saw the AutoWeek thing...Personal feeling is that the original is nicer. I can appreciate certain hot rods, but this one just doesn't do it for me.
I guess I'm just more of a traditional hot rod guy, with duece coupes and salt flat racer type cars. But, I'd always choose a LBC over a hot rod!
7 General TR Hot rod Triumph 0
Gray_Cat Hot Rod Sprite in Alhambra CA Spridgets 6
stuntflyr Hot Rod Healey question, frame color... Austin Healey 5
PAUL161 MGB Went to a hot rod show! MG 3
apbos TR2/3/3A California TR3 Hot Rod Triumph 3
J Bugeye "hot rod" on EBay Spridgets 9
Gundy hot rod bugeye Spridgets 6
Exotexs hot rod Jag Jaguar 4
Sherlock Hot Rod Jaguar Other British Cars 7
swift6 T-Series Fun Hot Rod MGTF... MG 4
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
Overdrive45 Stalling at Traffic Lights in Hot Weather Austin Healey 20
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
F Hot Ignition Coil Austin Healey 6
T TR6 Perfectly tuned TR6 wont start when hot. Triumph 11
T General Tech Running hot Triumph 8
KVH TR4/4A Hard Start When Engine Hot Triumph 20
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
D Lumpy Idle When Hot Austin Healey 2
K TR2/3/3A Thermostat for hot summer driving? Triumph 1
S TR2/3/3A Clutch pushes hard when engine is hot Triumph 4
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
R General TR Emergency hot wire - because you never know whats next Triumph 2
K TR2/3/3A Hot day coolant overflow issue.... Triumph 1
F TR6 Pegged out hot while cold Triumph 7
sparkydave Trouble running hot Spridgets 10
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
K TR2/3/3A Front brake rotors hot to the touch...... Triumph 6
T 1993 xj v12 red hot catalytic converter Jaguar 6
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
Bob_Spidell Running hot/Overheating Austin Healey 44
G TR4/4A Flasher Unit...VERY hot Triumph 10
Got_All_4 General TR Anybody Hear or Use This Hot Spark System? Triumph 10
pkmh How hot can it [temperature gauge] get? Austin Healey 4
dougie DD300 Runing Hot Austin Healey 6
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
glemon Hot Shot Other Cars 5
D Been waiting for a hot day run Austin Healey 4
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
J TR4/4A Too hot to drive a convertible Triumph 14
T Bj7 Overdrive slipping when hot Austin Healey 11
P 100M overdrive disengages on hot engine/transmission Austin Healey 9
F TR2/3/3A Starts Cold, Not Hot Triumph 12
M TR2/3/3A Why is my coil so hot? Triumph 6
D TR4/4A how hot does the timimg chain cover get? Triumph 15
F TR6 sticky valve when hot Triumph 4
Lutz Kramer Hot cams and advanced ignition Austin Healey 57
