Wedge TR7 rubber carb mounts
steve99
Last fall I replaced the rubber carb mounts on the TR7. At the same time I put a seal and gasket kit in both carbs and replaced the throttle butterflies. I replaced the butterflies because the edges appeared to be worn and scored. I put it all back together and all was well, (even got the idle speed down to about 900 rpm warm. The problem I'm having is that I seem to have a "catch" in the throttle at about 1/3 peddle, it seem to be just a sticky spot, however the resistance needed to overcome it increases with the engine temp. I thought maybe the shafts were worn, however they appear to be fine. Also the rear carb mount has failed, rubber seperated cleanly from the metal, I contacted VB and with a little whining (from me) they agreed to replace them. I thought the two were maybe related, but I dont think they are. Anybody have any suggestions, ideas, or input?
Izual Angel
Throttle cable need some lube? I dunno if that's something you do to a TR7, but I know some cars like a little engine oil in the cable sleeve once in a while.
My other thought is this. I noticed that my butterflies stick a bit near the bottom of the throttle bore (and I just rebuilt them). Could be the brass plate expands faster than the aluminum carb causing the extra effort you mentioned? Just a thought.
S
steve99
Thanx guys, I apprecieate the replays. I replaced the throttle cable last fall, and did oil it whrn I unstalled it. I disconnected each component of the throttle, (pedal, cable, linkage) and worked each seperatly, and all work just as they should. Right now I have both carbs removed, and both work just fine at ambient temp. I dont see any evidence of the butterflies rubbing on the inside of the carb bores either. Kind of scrtching my head on this one, however, IA, your suggestion about the different rates of expansion make the most sense yet. I'll keep you posted.
Steve
G
Hello,
Definitely lube the throttle cable at least on a annual basis. I do mine by disconecting it at the carbs and wiring the cable to the hood or whatever so it is verticle and gravity will push the oil to the other end of the cable. Make a funnel at the high end with tape and add oil. This makes things work a lot smoother and helps keep the cable from breaking when you are on the road. You might want to keep a spare cable in the boot along with the tools to replace it with because from experience I know they never break at a convenient time. Good luck.
Got_All_4 Wedge TR7 rubber 5 spd shifter boot Triumph 6
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
O Wedge 79 TR7 no start Triumph 5
M Wedge TR7 break fluid Triumph 7
johnrip Wedge tr7 tires Triumph 1
T Wedge Canadian TR7 catalytic converter when new? Triumph 0
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
Obtong WANTED: TR7 (Olympia/Seattle Area) Triumph Classifieds 0
T Wedge TR7 brake hard and flex lines - fittings Triumph 12
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
T Wedge TR7 engine, need help identifying part. Triumph 5
S Wedge tr7/8 quick release steering wheel Triumph 0
S Wedge TR7 fuse panel Triumph 8
Got_All_4 Wedge 1980 TR7 FI linkage Problem Triumph 2
johnrip Wedge TR7 led light conversion question Triumph 1
S TR2/3/3A Tr7 and a little extra Triumph 2
P Wedge Florida TR7 Triumph 0
S For Sale Weber Conversion Kit for TR7 Triumph Classifieds 0
1 Wedge Which Parts to get from an '80/81 TR7? Triumph 1
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
J For Sale TR7 stripped shell and parts Triumph Classifieds 0
johnrip Wedge TR7 carb seeping fuel Triumph 21
J For Sale 1981 Triumph TR7 convertible fuel injected TR 7 Triumph Classifieds 0
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
johnrip Wedge tr7 electric fuel pump Triumph 2
johnrip Wedge TR7 fuel pump Triumph 0
A Wedge Looking at a '80 TR7 ...... Triumph 4
TRopic6 For Sale TR7 Gearshift UKC 3248 Triumph Classifieds 0
Got_All_4 Wedge TR7 drive train torquing Triumph 2
GTP1960 Wedge "TR7 End of an Era" Hemmings article Triumph 11
N Wedge '80 TR7 Alternator Options Triumph 2
johnrip Wedge TR7 Brake squeal Triumph 1
tomshobby TR7 in TV show Spotted 2
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
JamesH Wedge new to me TR7, need some basic info. thanks. Triumph 2
bcbennett Wedge TR7 FASD vs. Manual Triumph 0
Got_All_4 Wedge Tr7 windshield factory windshield wires Triumph 3
K Wedge TR7 Project Triumph 10
Got_All_4 Wedge 1980 TR7 PI cutting out Triumph 4
Got_All_4 Wedge TR7 Volvo front brake converson Triumph 4
L Wedge TR7 gasoline odour Triumph 5
