1969 Mini Parking Lights
vance
I have asked this question else where with no results..
I installed driving lamps on the front WithOUT a relay..
All lights worked for awhile.. Then I lost the parking light
I have changed fuses,lamps,etc,etc.. I still can't get my parking lights to work...
Any Clue????
weewillie
do the driving lamps still work? and are they wired with a switch or through the harness
Steve
Platinum
The driving lamps......I assume that they are wired and fused seperately, and operate on their own switch? That being the case, they should not affect the parking lights.
In a Mini, aren't the parking lights part of the headlamps? Or do the front indicator lights illuminate instead?
I gather that you were planning on running with those and the driving lights on, and not have the headlamps.
Most likely suspect is the switch. First position, parking lights. Second position headlamps. Am I correct? (It has been years since I messed with a Mini, and it has an older one at that). This being the case, you should try a replacement switch and see if that works.
V
vance
Thanks for the reply...I forgot to tell everyone..I also replaced the switch...I wired the driving lamps directly to the parking light harness...I now realise I made a terrible mistake but still can't find out why the parking lights don't work.. I have since disconnected the Driving Lamps all together
Thanks
Vance
weewillie
I would be checking the wiring from the lights to the switch
Bruce Bowker
I know this sounds silly, but make sure the "new " bulbs you tried work. I have put many new bulbs in that were bad and spent a lot of time tracing elsewhere when it was just the bulb.
I had working driving lights on my Mini without a relay and they melted the switch. I do hope you did not melt some wires but as said already you will need to trace all your wiring.
Do you have a wiring diagram?
weewillie
I had driving lights on my 1100 without a relay Bruce and had them wired through a seperate switch with an inline fuse in the hot line and never had a problem
J Confusing Seat choices for 1969 Mini British Motor Corp 8
d_valentino 1969 Mini w/ automatic gearbox and air bags British Motor Corp 12
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
CJRams For Sale 1969 Jaguar XKE Jaguar Classifieds 0
AngliaGT 1969 Ford Galaxie Spotted 3
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
Quackedo TR6 1969 Triumph TR6 Differences Triumph 18
V 1969 Sunbeam Alpine coupe glovebox lock removal Sunbeam (Rootes) 0
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
S For Sale Triumph TR6 Workshop Manual on CD/ROM - 1969 - 1976 Triumph Classifieds 0
S For Sale MGC Factory Workshop Manual on CD/ROM - 1967 - 1969 Models MG Classifieds 0
oldbagpipe For Sale Early 1969 TR6 'Stalled Project' $4500 Triumph Classifieds 0
AngliaGT 1969 Impala Convertible Spotted 0
oldbagpipe For Sale Early 1969 TR6 Project for sale Triumph Classifieds 10
M Wanted MGB grill 1963 to 1969 MG Classifieds 2
Got_All_4 TR6 What is a 1969 TR6 seat worth? Triumph 5
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
Raymond MGB 1969 oil filter MG 4
C TR6 Need help with a 1969 triumph tr6 Triumph 21
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
L For Sale 1961-1969 AH Sprite, MG Midget Chrome bumpers & hardware Spridgets Classified 0
C Brake issue on my 1969 XKE - what to check first? Jaguar 14
June TR6 1969 tr6 Triumph 17
B MGB Normal oil pressure at all tempratures for 1969 MG-B MG 12
S MGB 1969 MGB No spark to plugs MG 5
jmayzer 1969 sprite - good deal?? Spridgets 17
W What motor will fit my 1969 Austin Healey Mark IV Spridgets 29
W What motor will fit my 1969 Austin Healey Mark IV Austin Healey 5
RickB As seen on Craigslist [Seattle area] 1969 Austin Hensley [SIC] Spridgets 0
A 1969 Sprite. Month: 8 Spridgets 2
H 1969 Jaguar XKE - Oil Jaguar 7
aeronca65t 1969 Watkins Glen F1 Racing 9
S MGB-GT FS: 1969 MGB GT 64k miles, overdrive, a lot fresh. MG 18
T Difference between 1969-74 and later exhausts Triumph 7
AngliaGT 1969 LeGrand FF - Anyone Have Info? Racing 2
S Spitfire For Sale: 1969 Spit Fire MK3 Triumph 1
K clutch 1969 sprite Austin Healey 4
T TR6 WTB - 1969 TR6 fan Triumph 7
JRC Spitfire SF Chronicle - 1969 Spit Triumph 2
D 1969 Austin Healey Sprite Rebuild Spridgets 16
Z MGB MGB 1969 Trim query MG 6
abarth69 MGB-GT 1969 MGB GT with automatic MG 2
J New 1969 Midget owner here. getting rid of parts Spridgets 27
C Uh Oh, I do I really have a 1969? Spridgets 36
AngliaGT TR6 1969 TR6 - Why? Triumph 4
