TR6 Need help with a 1969 triumph tr6
ChrisBCliff
A week ago i was troubleshooting the marker lamps and the car would turn over at the time, but not start. I went to test it today and now the ignition light doesn't even come on. Help please.
Clean battery posts and clamps, doesn't take much sometimes to keep it from making a connection. Where is your negative/ grd cable connected? Remove it from wherever it is mounted and clean both surfaces. If it is factory cable it should be mounted both to the engine and body.
Marv
glemon
Check the positive connection at the solenoid too, all the power goes through that point. If it corrodes you get the same symptoms as a bad ground. I had this happen on my TR4a once.
poolboy
A lot goes thru the wires to and from the ammeter...you might have to check that out.
C
ChrisBCliff
Ammeter works fine and still does. I need to know why the ignition stopped working. The engine just stopped turning over one day.
poolboy
Yeah, I get that...Have you looked at a wiring schematic specifically for a 69 TR6, though ?
C
ChrisBCliff
Yes, i am using a haynes manual for the car. It just doesnt go as in depth as i'd like. Sorry, just a little fed up with some rust around the headlights
glemon
I usually try to isolate/track the problem by the easiest means possible before digging into things too much. Just to verify, it sounds like you aren't getting juice to anything-ignition switch no click-nothing? No headlights or horn? (Should work regardless if ignition on or off). If no power whatsoever you might also check battery cables, they can look ok and be bad. If the horn and or headlights work might check the ignition switch.
Lastly, you said you were working on electrics before it quit. I often have found if something worked before I mucked around with the car, and no longer works after, it can often be traced to what I mucked around with. Not necessarily did anything wrong, but if you disturbance system where some part is marginal it can easily go from working to inop.
rjc157
Chances are it's a loose wire somewhere check what you did and make sure it's connected properly and grounded get a test light and start from the battery and work your way down to the starter then the coil
Got_All_4
Do have power to the exciter wire (white with red I think) to the solenoid when you crank the engine? Do you have power to the ignition switch both in and out. If not try running a jumper to it and see what comes out the other side. That would eliminate switch problems.
Sarastro
I think you need to do some systematic troubleshooting to find the place where you're losing voltage. That means, use a voltmeter or a test lamp and trace the circuit from the battery, through the switch, and find the point where the voltage disappears.
Also, a little basic logical thinking would help. If the whole car is electrically dead, the problem isn't going to be the ignition coil. It is likely a bad connection close to the battery or a defective switch. Looking at the connections and pronouncing them OK is probably not the best way to go--things can look good and be bad. A voltage measurement will be more meaningful.
Marksg11dna
Ney Chris, you should get 4 ohms on the coil. Are you getting any power, lights? Does it crank? If not I'm thinking ignition switch area.
C
ChrisBCliff
So i have gotten the car running and i drove it for a long time, but recently it has had some difficulties getting the car started. The solenoid only engages a third of the time, and when it does engage it doesn't turn the starter motor. I took the motor off and used a separate power supply to test it and it turned over with power. There are no battery issues and i have checked all of the electrical connections to find no faults. Why won"t it turn over?
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Navigation Questions 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Navigation Questions 1
F Help need reinstating my heater - BT7 Austin Healey 7
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR4/4A Need Help Finding Triumph 3
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
D 68 Sprite value - need help Austin Healey 9
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
B TR2/3/3A Need help with tr3 project Triumph 9
V General TR Need help with installing glass and new seal into my surrey top. Triumph 2
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
Steve P. Need help with oil filters Spridgets 1
RickPA Need help installing steering idler oil seal Austin Healey 6
M TR4/4A Need help with TR4A brakes Triumph 10
Willie_P TR4/4A Alloy Valve cover: STUD SPECIFICATION - need help!!! Triumph 5
Rut MGB Need turn signal help MG 15
D Need help please Spridgets 4
D Need help please Austin Healey 2
