Results 1 to 4 of 4
Thread: Speedometer Tach Correlation 1965 Austin Healey BJ8
  1. #1
    Join Date
    Sep 2018
    Location
    Humble, texas
    Posts
    2
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Is there a table somewhere that I can check to see the correlation between my Tach and speedometer?
  2. #2
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,917
    Thanks Thanks Given
    16
    49
    Thanked in
    Re: Speedometer Tach Correlation 1965 Austin Healey BJ8
    Rick
  3. #3
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,907
    Thanks Thanks Given
    104
    167
    Thanked in
    There are tire size/gear ratio/rear axle ratio calculators online, like this:
    http://www.advanced-ev.com/Calculators/TireSize/
    The Road & Track test for your car lists 23.3 mph/1000 rpm in overdrive.
    Listed overdrive ratio is 0.82. With the stock 3.91 axle, giving an actual of 3.21:1
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  4. #4
    Join Date
    Mar 2003
    Location
    Hampshire in the UK
    Posts
    1,765
    Thanks Thanks Given
    8
    Thanked in
    Now if you had a 100/6, the drivers hand book ( I have an original complete with a receipt for a pint of oil which cost 2 shillings and 7 pence way back in 1966 ) you would have had two tables - one for OD and one for non OD each listing the MPH, and KPH with the gears and the revs in in each gear. Sadly they do not do it for the BJ7 - well not in my copy any way and I doubt that it was in the BJ8 hand book either.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
