Hey Guys, once again I need to tap into your infinite wisdom. The PO had installed all VDO gauges in my Bugeye except the fuel gauge. I bought a matching 0-90 ohm VDO gauge and a replacement 0-90 ohm sending unit from Moss. I've had my gas tank out 3 times, which we all know is 3 times more than we want, to get it to work with no success. I've heard from a knowledgeable source, Morris Mintz, that I need a VDO sender to make it work. Problem is I didn't find a 0-90 ohm one and the mounting is different, 5 holes to 6 on my gas tank. Suggestions? Thanks
Bookmarks
