Results 1 to 2 of 2
Thread: VDO Compatibility
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Join Date
    May 2019
    Location
    Rio Rancho, NM
    Posts
    5
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    VDO Compatibility
    Hey Guys, once again I need to tap into your infinite wisdom. The PO had installed all VDO gauges in my Bugeye except the fuel gauge. I bought a matching 0-90 ohm VDO gauge and a replacement 0-90 ohm sending unit from Moss. I've had my gas tank out 3 times, which we all know is 3 times more than we want, to get it to work with no success. I've heard from a knowledgeable source, Morris Mintz, that I need a VDO sender to make it work. Problem is I didn't find a 0-90 ohm one and the mounting is different, 5 holes to 6 on my gas tank. Suggestions? Thanks
  2. #2
    Yoda dklawson's Avatar
    Join Date
    Mar 2005
    Location
    Durham, North Carolina, USA
    Posts
    6,194
    Thanks Thanks Given
    49
    Thanked in
    Re: VDO Compatibility
    You should be able to use the Smiths 0-90 with the VDO 0-90. Morris may have been referring to another combination of gauges and senders.
    However, as you pointed out, you don't want to take the tank out any more often than you have to. Therefore, bench test the setup. Use either your battery charger or the battery in your car as a power supply. The gauge will need its positive and negative terminals connected to your power supply respectively. Run a jumper from the gauge's ground terminal to the flange of the sending unit. Lastly, run a wire from the gauge's sending unit input to the insulated terminal on your sending unit. Power up and work the float arm through its range of motion while you observe the behavior of the gauge.
    Doug L.
    '64 Morris Mini Cooper-S 1275
    '67 Triumph GT6 Mk1
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
